discovered telescope wheel not working
I thought it was working on the test drive, it makes some sort of not really grunt but beep when it tries.....I actually prefer the wheel as far away and low as possible, so I guess it's ok? The tilt seems to be fine, although when I forced it, it temporarily stopped. Part of me wonders if I should disable the tilt? But I kinda like it going up when exiting, feels like a luxury feature lol
I thoroughly tested the mirror control, and the "up" arrow has intermittent issues. But, since I have my memory set, that should be ok.
Loaded up the 6 cd changer--that seems so archaic, but seriously, the sound is a lot better than FM stereo....my buddy said the car is a time capsule to 2006!
Yes, carefully remove the cover and clean them contacts up real good like.
Should work wonderfully afterwards. Mine did anyway...
Gotcha, thx on the mirrors. I would advise anyone to have a memory setting with the proper adjustments, just in case. I'm thinking about pulling the #1 fuse on the tilt and telescope thing.....
edit: I decided to take out the #1 fuse, with the wheel in the proper driving position....it has never not responded to the button as far as tilting, but for whatever reason, it would sometimes not go to the correct position when the ignition turns on--rather not get into a situation where the wheel can't be put back to the driving position. Again, nice to have it auto tilt out of the way, but all of our other 3 cars have tilt/telescope, and manually operated. And we never use it at all....
T&T is cute but the possible repair costs aren't worth it. On my 01, both worked fine. Had the shop disable T&T (using software). Can still manually adjust tilt but now telescope doesn't work. Is this normal?
In your case, the automatic retraction was disabled, but you still have power, so you are similar to I was, i.e. tilt seems to work, telescope does not. So it's not normal, I think your telescope motor has failed. Mine made a tiny peep sound when you try to use it, so something is happening, just that the motor cannot do its job. one time I forced it so it did come out. But I like to drive with it all the way in, so I did not want to fool around too much....and prefer to leave it all the way down, and all the way in (how I like it)....
The motors are a known weak spot in these cars. If its acting up the motors are usually on their last legs if not dead completely. Youll hear small chirps of the motor trying but nothing happens. I did my tilt motor when it died. Now have to do the telescopic. I like everything to work as it came from the factory.
Gotcha the telescope has a chirp...I would like it to work...but I tell myself we never use it on our other cars, on which tilt telescope is manual..haven't put my finger on it, seems even with memory doesn't always go back...
