Rear hub replacement
I replaced the rear hub on my 430 this weekend just like the post. But with my luck the old hub came out in two pieces instead of one! It was quite a job getting the one assembly off. But fyi a crowbar and a flat head screwdriver behind the ebrake pride it right off. Thanks for the step by step info guys!
Here's a quick write-up on replacing the rear hub... https://www.clublexus.com/forums/ls-...del-ls430.html
How far have you gotten?
You may have to repeat Step 10 (pry from the speed sensor hole) and Step 11 (pry from the lower brake caliper bolt hole) alternately a few times to loosen the dust deflector. The dust deflector is made of steel so it will flex a bit. Be patient... it will come loose eventually.
ABS axle dust cover
tech coming by Tuesday to look at it. Thanx for the encouragement
