Replacing plug sub assembly 69207L and 62908a
I had the body colored trim cap missing when I bought it, so I decided to replace it. The front door was easy, pop the old one off and pop the new one on. The rear ones are more involved.
I removed the door panel, plenty of write up on here about it,
then I peeled the plastic sheet back directly behind the door handle.
I unbolted the door lock accuator and door lock catch.
<br >
<br >
Next I wiggled the assembly down as far as I could, it's not attached to the handle, and it exposes this little gem
<br >
This is what holds the trim piece on
<br > <br > <br > <br >
Everything goes together just the opposite as it came apart.
Be careful with the child safety lock switch, I didn't break it off, but I can see how it could happen. Once I got the door lock assembly pushed back up and bolted in place I tested the handle, worked great.
Wish it would have been as easy as the front door!!
<br >
<br >
<br >
gulleyman
GS - 1st Gen (1993-1997)
15
09-19-21 08:05 PM
Lubeboy
SC- 1st Gen (1992-2000)
05-30-17 12:52 AM
