Purpose of little light?
Old 02-23-16, 08:14 PM
ryanSC300lover
ryanSC300lover's Avatar
Default Purpose of little light?
Anyone know the purpose of the little lamp that is in the high beam headligh housing up top pointing straight down on the 04-06 LS ?
This light is only on (yellow color) when low beams are on
Appreciate any help
Old 02-24-16, 04:17 AM
Lavrishevo
Lavrishevo's Avatar
Decrotive lighting. I know the one your talking about and I can't imagine any other reason to have it.
Old 02-24-16, 05:52 AM
jimbosr1
jimbosr1's Avatar
i changed that light before and its a pain to get to it.
Old 02-24-16, 07:10 AM
KING
KING's Avatar
Parking lights as they like to name them.
They illuminate the high beam shell, giving it a nice look. I switched the original bulbs with white LED's.
You can see the difference. Especially at night.
The passengers side has the new LED, drivers side still has original bulb.
Attached Thumbnails Purpose of little light?-photo514.jpg   Purpose of little light?-photo593.jpg   Purpose of little light?-photo173.jpg
Old 02-24-16, 03:01 PM
ryanSC300lover
Perfect
Would you care to share
1) which led to get
2) how difficult to do?
3) any warning lights pop up on instrument cluster switching to led?
Old 02-24-16, 04:46 PM
KING
KING's Avatar
Originally Posted by ryanSC300lover
Perfect
1) which led to get
1) I believe it is this one. From "Super Bright LEDs"
https://www.superbrightleds.com/more...car/1728/4112/
2) Takes like 5 minutes, just remove the black plastic cover that covers the edge of the headlight. And you will have straight access to it. If your hands are tiny enough you can do it without taking the plastic cover off.
You'll see a wire and a plastic clip on that attaches to the headlight right over this bulb we are changing. Twist counter-clockwise and it would pop out, take old bulb out, put new bulb in. Reverse steps.
3) Nope, nothing.
Old 02-24-16, 04:48 PM
ryanSC300lover
Man you rock
Thank you so much
It bothers me to no end to see that grossness on the front end at night
Owe you one !
Old 02-24-16, 04:54 PM
mjeds
mjeds's Avatar
Appreciate any help
"front position lamps" aka parking lights; required in Europe and Asia, I suspect that Toyota feels it's pointless to make a different set of headlights for American builds.
Old 02-24-16, 04:56 PM
ryanSC300lover
Understood
But they spend all this money on nice headlights and nice led tails, they could have either turned that little bulb off when headlight on, or made it led
KING
KING's Avatar
Man you rock
Thank you so much
Owe you one !
Happy to help, brother!
Don't forget to order 2 *Don't ask.
Old 02-24-16, 05:12 PM
mjeds
mjeds's Avatar
Understood
possible, but as I said, they are required in Europe and Asia. so I doubt Toyota went about making anything different.
if you look up the lighting requirements for most of Europe and Asia, that light has a requirement to be on with and without the headlights, and it has specific output and color requirements that LEDs may not meet.
here is the lamp requirement for the UK:
http://www.vehicleliverysolutions.co..._48_r48r6e.pdf
the front position lamps are required designate the width of the front of the vehicle, and must be a light independent of the headlight and turn signal (where in the USA parking lights and turn signals can be dual filament bulbs), and the parking lamp must be a different independent bulb.
additionally if you look at section 5.7.1.1 it indicates that the color of the position lamps must match the color of the lamps that they are required to be activated with (i.e. the headlights), therefore they cannot be an LED they must be a halogen bulb similar in color to the headlight bulbs.
Old 02-24-16, 06:46 PM
ryanSC300lover
But the headlights are not halogen and the color doesn't match
Old 02-24-16, 07:05 PM
mjeds
mjeds's Avatar
don't know my friend, only pointing out what I do know.
Old 02-24-16, 07:06 PM
ryanSC300lover
Appreciate it the info
Old 02-24-16, 09:42 PM
aypues
aypues's Avatar
I thought they were called clearance lamps. I replaced mine last year...actually I replaced ALL of the front end bulbs except the fogs.
Quick Reply: Purpose of little light?
