05 UL - Squeak Noise on Bumps - Passenger Side
Every time i hit a bump, I notice a quick squeaking noise coming from the front passenger side. Sounds like it is coming from the door or glove box. Right side only
Does anyone know what this could be? I have air suspension BTW.
Thanks in advance.
Thanks in advance.
I had to replace both outer tie rod ends when my sons car started squeaking badly. You might inspect them to see if the boots are torn or you can move the tie rods freely.
have you ruled out the front swaybar bushings?
Could be the weather.
A suggestion if this is the problem: remove the bushings and wrap the swaybar section where the bushings are with teflon tape and re-install the bushings
DshngDaryl
04-16-19 05:14 PM
LuxSedan92
05-08-08 11:47 PM
