Failing latch for driving glasses compartment
The latch on the driving glasses compartment near the rear-view mirror is stuck (2001 LS430 UL). I tried a silicone spray and it made it worse. This same condition occurred in my previous 2001 LS430. Any ideas on a fix or replacement protocol?
Thanks, Dan
Thanks, Dan
Had the same issue on my '01, Dan. I tried to make the latch work but it wouldn't cooperate. I ended up replacing the assembly with a recycled one. Suggest that you contact recyclers (including those on eBay - if they have a '01 - '03 LS) and price it.
It's the spring-loaded push button lock that is attached to the overhead console assembly with two screws. I don't have a part number for you, Dan. Lexus told me they don't sell that individual part. Ask your L parts department to verify.
Mine drops down and will not latch when it is -20F. I will come out after sitting all day at work and it is open.
Just a reminder of how fun -20F is. I might get a part if I can DIY fix.
I had this same problem. The latch is not broken, it is just sticky, and will not give a positive "return-to-latched" when retreated. Does anyone know if this part (the latch assembly ONLY) is available for order? Many thanks.
chuck
chuck
