Finally fixed my front end clunking noise
I've had a clunking noise on my 2005 since I picked it up in July. It's most apparent when the left front wheel drops off a curb when doing a right turn. I've had the car up on the lift 3-4 times (while doing other stuff) and never found anything lose or worn out. Yes I checked/tightened the camber bolts. The noise sounded like something heavy held on with a bracket and that bracket was lose or maybe the brake pads were rattling around (which they aren't).
Couple of weeks ago I did the front struts since, at 91k, it's probably time and I thought maybe a strut (or mount) was damaged or something. Didn't change or eliminate the noise but certainly helped road feel. Need to do the rears now.
The lower control arm bushings looked OK, but had cracks in them, so they were on my list. Finally got around to doing them today. Fixed the problem completely.
I still have no idea how a worn LCA bushing could lead to the noise I heard, but it's gone and I ain't complainin'.
AN
AN
thats not surprising considering how much movement there is at that lower bushing. I've been getting some occasional shakes when braking and when cruising at highway speeds on my car with 60k on them. I'm going to order some genb offset bushings soon.
Here is a video from Fig's showing the lca bushing on an isf which shares a similar lca bushing setup that we have. I wonder if their bushing set will fit our cars.
Thanks!
Which bushing(s) did you replace? The entire lower control arm or bushing 2, or rear bushing?? I'm ready to do this but need to know what to replace just to be proactive and regain a new car feel.. I didn't want to replace the entire lower control arm if I didn't have to. I know about the rear bushing and No.2 and that's about it. I had my suspension checked and they couldn't find a problem but
Thanks!
Thanks!
Also, a few notes on the bushing: There is no lip on the bushing housing; I think you can press it out in either direction. I got it out with a 20 ton press. No issues except that first 'pop' is pretty scary. You need a cup that's just slightly smaller than the bushing on top and a cup that slightly larger than the bushing underneath. Sorry I didn't measure. I more or less used this:
I say more or less because I used old wheel bearings and a press to pop the bushing out about 1/2 an inch. Then I used the right sized cup from that kit on the bottom of the bracket to continue pushing the bushing out.
Hey Thanks. That youtube video showing the flex on that bushing is crazy.. I didn't think it was getting as much action as it looks like on that video. Of course that's a sportier car but I'm sure it wouldn't be too much different.
Great video. Mine have been cracked for 5 years. No vibrations, noises, tire wear etc. I guess so far I'm lucky...
It's sort of like motor mounts, once you get them replaced you discover how smooth it was "supposed" to be
But if you're happy with the ride and have no alignment issues, it's probably fine to carry on
It's one of those things you don't really notice until it's been replaced.
Yeah, I have yet to replace my LCA bushings. My driver side front has serious clunking when going over potholes or rough roads. I am pretty sure it is the LCA bushings that need replacing. These are liquid filled, no? Where did you buy your replacement parts from?
I ordered mine from mylparts.com. You can use the code CL5 on checkout to get a discount. I'm in CA (they are too) and I get stuff way quick from them. They are great!
Michele01
Suspension and Brakes
10-18-17 02:04 PM
