Brake Wear Light On After New Pads Installed
The light wasn't on before I replaced the pads yesterday. While I was bedding the pads the light came on. As I understand it, my only options are:
1) Installing new sensors from the dealer
2) soldering the wire together to recreate the loop.
Any other choice? Thanks.
3) Install new sensor from Rock Auto
Last time I checked Raybestos had some for $15-20. Visually inspect or check the resistance at the sensor plug using a multimeter to find which loop has been cut. You may need only 1 - in which case it's half price.
If it was me (and the sensors weren't destroyed) I'd remove them from the brake pad locations and zip tie them out of the way so the light never comes on again. I just replaced my rear pads as the sensors were just starting to 'touch' (no light on yet). But I still had a LOT of life left on those pads. In the future I'll just check the pads myself, don't need the idiot light to tell me I need pads 20,000 miles before I do.
We do our own repairs, but for 80% or more of owners that don't, how is a sensor that monitors wear a gimmick? Owners don't pull wheels off once a month and check pads. I think is a perfectly better option than the squeal sensors that are just annoying.
If owners don't have a brain and expect their brakes to last forever then I guess it is okay. Normally you would expect people to periodically check them - at least that's what people did before sensors. Once every 20,000kms would probably suffice. Also seems kinda stupid to have non re-usable sensors that are almost the price of a set of pads - at least from Lexus. I don't see the advantage personally.
wnyjazz (05-22-19)
Not only because these sensors are super cheap to replace, but it's good practice to always have your car set up the way it is supposed to.
It makes things easier for the 2nd owner. Many times have I found the previous owner cutting corners on lots of cars I owned. It's just frustrating. It's not clean and it just makes every job a surprise.
So, do yourself a favor and slap a new sensor on that pup.
Mega
11-07-12 02:11 PM
billy boi
07-15-05 06:12 PM
