P0440
Old 10-18-15, 12:45 PM
DiamondX
DiamondX's Avatar
Default P0440
Hi, all. I received a CEL that indicated a P0440 code the other day (2002 LS 430). The first thing that I checked was the gas cap and found a crack in the O-ring. I replaced the cap with a Stant brand cap. I didn’t have the code cleared because I thought that it would go away after a while, but it hasn’t. A poor assumption on my part? I am still getting the CEL. Rather then heading to the repair shop, I wanted to as you all if Stant is still a reliable brand or do I actually need a genuine Lexus cap? Thanks.
Old 10-18-15, 01:54 PM
doodoo
doodoo's Avatar
You can erase the code via scanner or disconnect the battery for 5 minutes. Then see if code reappears. The gas cap brand shouldn't matter. As long as it has a good seal so there is no leak.
Old 10-18-15, 08:15 PM
DiamondX
DiamondX's Avatar
Thanks. I'll give a try.
mizak82
RX - 1st Gen (1999-2003)
02-01-21 06:22 PM
EJ255t
09-01-16 03:40 PM
cwalk
01-14-13 06:41 PM
Patsum
07-13-12 12:43 AM
JohnGS4
04-11-07 07:50 PM
Quick Reply: P0440
