wheel nuts
wheel nuts
bought some aftermarket wheels. They did not include wheelnuts to fasten the wheels to the hub.
The supplier suggested to get aftermarket lugnuts.
My ? if the manufacturer of these lugnuts have to match the Lexus OEM studs why can I not use the original?
Is it advisable to use steel nuts on an aluminum wheel?
Just use the originals and a torque wrench with the correct spec to install. There should be no issues. If you need a second set they are around $5.00 each from the dealer.
The only reason to go aftermarket is looks or cost. If you go too cheap the bolts will damage easily and rust quickly.
so its not just for looks. more on the sides of safety
wheel nuts
thanks for the info
In the meantime I contacted the manufacturer and THEY have the correct nuts, It is a 60 deg tapered seat; the lug set is available at their local tire/wheel supplier.
Problem solved
Problem solved
Revived
10-20-17 09:36 AM
Sportskid1
06-13-14 07:37 AM
