Door lock troubleshooting sequence?
Old 08-24-15, 01:46 PM
lexusfan05
lexusfan05's Avatar
Default Door lock troubleshooting sequence?
I have read the threads on door lock actuator and cable failures. Is there a step by step troubleshooting guide on this issue?
My problem on my 2001 is that the remote built into the key base will fail to lock or unlock intermittently and works most of the time. The manual key in the keyhole always works ( I have only tried on driver side) and the switch always works from inside. This makes me think that the motors are fine, otherwise the switch from inside wouldn't work. I am also thinking that it's not the remote because when it does not lock (and does not beep), i can "unlock" it and it will double beep. Is it a stretched cable, or some sort of ECU issue? How do I tell which door is the problem?
Thanks in advance.
Old 08-24-15, 02:23 PM
Lavrishevo
Lavrishevo's Avatar
It's the actuator motor. You can always manually operate the lock. When the motor is failing it works intermittently. Just be glad it's the easiest and cheapest part to replace.
Old 08-24-15, 02:28 PM
lexusfan05
lexusfan05's Avatar
Thanks. Is there a way to tell which door is failing? Or should I replace all 4?
Old 08-24-15, 02:58 PM
Lavrishevo
Lavrishevo's Avatar
Nobody really replaces all 4. The way you tell which one is failing is by seeing which door lock is not responding. It's usually the door used the most. My drivers door was replaced twice. Once under warranty by the previous owner and once by me. Which door is intermittent?
2002RX300
RX - 1st Gen (1999-2003)
44
12-15-15 06:04 PM
islexusred
12-03-13 02:26 AM
SureShot
07-11-13 11:43 AM
cruss
Florida Lexus Club
07-13-12 07:48 PM
khilgers
06-15-12 03:20 PM
Quick Reply: Door lock troubleshooting sequence?
