Engine compartment -heat concerns
Old 08-02-15, 12:25 PM
Fixman
Fixman's Avatar
Default Engine compartment -heat concerns
Hi.
I was just wondering regarding engine compartment heat.
Ok hear it is parked the car about 6 hours a go, was just checking the fluids and the engine compartment is hot and I don't mean warm. I now it is a cramped in there but is this normal, it's hot hear now it's about 35 c. But the the compartment is like 50 - 55 c after 6 hours. That is about 20 about ambient.
Old 08-02-15, 01:18 PM
jayclapp
jayclapp's Avatar
I wouldn't worry about the cool down temperature under the hood. The cylinder walls of the engine are quite hgh when the engine is running and those temperatures have to dissapate after the engine is shut down. Some parts may even increase in temperature somewhat because there is no cooling available other than ambient air. All automobile with combustion engines have this in common.
Old 08-02-15, 01:26 PM
Fixman
Fixman's Avatar
I know that. But it seems high to me. So was just wondering.
Thanks for the assurance.
Old 08-02-15, 07:05 PM
Anthony81
Anthony81's Avatar
I notice a lot of heat coming from the engine when I open the door to get out, but I figure it is normal.
Old 08-03-15, 01:21 AM
KING
KING's Avatar
Hahah I was in Dubai last night. Temp reached 53 celsius on the big clock on Sheikh Zayed road next to DXB!
I can understand your concern.
BUT, I have left my old LS430 with the AC on max in temperatures reaching 45-48 celsius for 3-4 hour intervals, and have never faced a problem. Not that I would recommend it nor want to do it again. Just more assurance that the Japs have put in mind that these cars will be driven around a lot in very hot climate areas.
Just make sure your coolant is topped up, and your eye on the engine temp.
Old 08-03-15, 08:00 AM
Fixman
Fixman's Avatar
Agree on the quality of japanes engineering, and Lexus IS eavin higher. All LS is belt in Tahara plant, look it up its one of the most quality issues factory of any kind the the world.
That bring 2 mor questions.
1) Is the Gulf spec LS430 radiator is the same as the Amirecan, I have heard that the Gulf spec is a 3 core radiator.
2) My care have a lot of radiat heat coming from the flore, to the point that the AC bearly keeps me cool. It dos blow coold but there is a lot of heat coming from the floor. Of course the issue is exaggerated in stop and go traffic.
Old 08-03-15, 09:31 AM
KING
KING's Avatar
Originally Posted by Fixman
Agree on the quality of japanes engineering, and Lexus IS eavin higher. All LS is belt in Tahara plant, look it up its one of the most quality issues factory of any kind the the world. That bring 2 mor questions. 1) Is the Gulf spec LS430 radiator is the same as the Amirecan, I have heard that the Gulf spec is a 3 core radiator. 2) My care have a lot of radiat heat coming from the flore, to the point that the AC bearly keeps me cool. It dos blow coold but there is a lot of heat coming from the floor. Of course the issue is exaggerated in stop and go traffic.
Yup, GCC specs have an extended radiator, bigger in size.
Don't worry about heat coming from under the car. Very normal keeping in mind the climate and how it is where you live.
Old 08-03-15, 10:08 AM
Fixman
Fixman's Avatar
Thanks.
The heat from outside the car is ok. Got that.
Ok mor clarification, siting in the care and AC on after 20 minutes or so I feel heat radiating from under the seats, if you open the storage compartment under the seat it is varry worm. Basically the heat from the engine and exhaust is heating the flore pan and this heat is trasmited to the inside of the car.
After reaching home and the care is parked in the garage (open from 2 sides) no direct sunlight. When I look the car it's cool, after 1 hour it's varry hoot, as if the heater is on.
Old 08-03-15, 10:18 AM
Lavrishevo
Lavrishevo's Avatar
Long periods of idling is bad for any car and causes carbon build-up and possibly damaging the the catalytic converters. If you look at the user manual it states to not let your car idle for more then 20 min without driving it.
Old 08-03-15, 11:00 AM
JffGRY706
JffGRY706's Avatar
check your heat shields around exhaust system. previous owner might have removed and not replaced. maybe make them bigger or something just guessing
Old 08-03-15, 11:27 AM
Fixman
Fixman's Avatar
That is what I am planing to do. As the rear mufflers are not the OEM, planing to refit the OEM as of now it sounds ugly (my taste) it sounds like a German OR Japanes 6 cylinder (BMW, Supra, GT-R ...) the constant loud sound (booooooo).
For that need to jak up the car witch will not be at home.
If any one have pix of the exhaust system for compaction will be grat.
Old 08-03-15, 12:10 PM
JffGRY706
JffGRY706's Avatar
1 in a row .....sweet, lucky guess what is top speed of gulf coast version. USA is 130 mph, just asking
Old 08-03-15, 12:45 PM
Fixman
Fixman's Avatar
Can't say as mine is a U.S spec.
If I am not mistaken ther is non. But if ther is it will be mor than 130 (208 km/h) as I have heard of other driven more than 156 (250 km/h).
Lavrishevo
Lavrishevo's Avatar
I little over 160 mph is where the 430 tops out without a speed governor.
deadthing
IS - 1st Gen (2001-2005)
06-03-16 07:30 AM
GX460PREM
GX - 2nd Gen (2010-2023)
05-22-16 02:32 PM
Speedy0o
Hybrid Technology
15
12-01-14 11:59 AM
mnm27mnm
01-19-14 04:47 PM
kingkirby
07-04-09 08:15 AM
Quick Reply: Engine compartment -heat concerns
