Alignment through Groupon
Yaw is rotation about the vertical axis (in this case, going through the center of the detector).
The yaw rate sensor only measures the RATE of heading change (i.e.the angular acceleration), not the deviation from its original heading.
You could be heading 90 deg. from your original heading, but if you stop turning, the yaw rate sensor will indicate zero.
excluesive
Suspension and Brakes
03-31-10 06:47 AM
Quick VR-4
03-03-10 01:48 AM
