Alignment Results posted.... Tire wear???
Looking for some advice...
2005 LS-430 UL with Air Ride. Car has been lowered with Data Systems controller.
I have attached the results of my recent Alignment. The Right Rear Camber is out of spec = -2.5.
Will this cause tire wear?
Thanks!
Thanks!
This part will add about .75 camber in my experience if you want to get it in the green zone near -1.75 degrees in your case. That was my issue too but mine was slightly worse off. The shorter arm can be found for $50 shipped on eBay as I did.
kenTHUNDER
12-21-13 08:06 PM
