Replace Timing Belt After 108 months?
Old 02-01-15, 01:03 PM
  #31
Devlyyn
Devlyyn's Avatar
Thanks for all the encouraging words. I did buy the AISIN kit that includes the water pump. The whole thing is basically coming apart so hopefully any other previously hidden problems will show themselves. I guess I can never know if the odo was rolled back, but I can try to fix things now. I did get a pretty good deal on the car, and as long as the engine isn't totally shot, I still should do alright hopefully.
I took it in to the mechanic for a once over before I bought it and everything looked great. Goes to show, you never know what lies beneath sometimes! I'll take a better look at the belt too, I wonder if it was some cheap replacement from the original\.
Old 02-01-15, 04:22 PM
  #32
Lavrishevo
Lavrishevo's Avatar
Both kits come with the water pump that are oem. The Aisin kit. Only one comes with the tensioner and idle bearing. TKT021
Old 02-06-15, 08:07 PM
  #33
Natey2
Natey2's Avatar
Is anyone changing their serpentine belt when they do their timing belt? I hear the former has to be removed and put back to get to the TB.
Sent from an Android device using IB Automotive Group forum reader.
Old 02-07-15, 05:30 PM
  #34
toddmorr
toddmorr's Avatar
i didn't. What you heard is true, but its very easy to get to and replace all by itself, meaning it took me around 20 min start to finish. The original belt lasted around 60k miles, at which point it started to make a faint squealing sound. Replaced it with $30 Gatorback belt, no problems now.
Old 02-09-15, 04:25 PM
  #35
daGOAT
daGOAT's Avatar
Is there a quick way to visually check the T-belt without actually removing any parts?
Old 02-09-15, 05:10 PM
  #36
randal
randal's Avatar
The answer, unfortunately, is "no". Mileage/time is the best way. You have to at least remove some covers to see the belt.
Old 02-09-15, 05:16 PM
  #37
randal
randal's Avatar
The serpentine belt generally refers to the accessory belt which drives the alt, AC, PS pump, etc.
It is a rather easy part to change. It all depends upon how old it is when the TB is done. If relatively new, I just put it back on when doing the TB. If older(50k miles or more), replace it. Its easy, so no biggy.
dmhosler
06-17-21 01:36 PM
retiredva
14
04-17-11 11:00 PM
SILVRLININ
01-17-11 10:53 AM
pienomiko
Maintenance
03-10-09 06:48 PM
Quick Reply: Replace Timing Belt After 108 months?
