BuZZing Sub-Woofer
Old 04-22-14, 04:36 PM
drdarell
drdarell's Avatar
Default BuZZing Sub-Woofer
My 2002 LS430's Sub-Woofer just started to Buzz. My thanks to the folks that have pointed out how to get to and remove the Sub. Also found a good replacement for $8 but it doesn't work for the UL so I'm out of luck there. Learned about re-foaming the speaker and watched it on You-Tube.
and the nice folks at Simply Speakers.com have kits so you can re-foam your Lexus speakers for under $30. http://www.simplyspeakers.com/lexus-...edge-kits.html
Just bought my kit. I'm about to replace my rear air shocks so while I've got the rear seat out I'll fix my Sub-Woofer as well.
Enjoy
DrDarell
Old 04-22-14, 10:20 PM
Riick
Riick's Avatar
Don't forget to shim out around the speaker coil - matchbook cover works well, as would matches themselves.
Old 04-22-14, 10:56 PM
Gene01
Gene01's Avatar
I am curious - why would a given subwoofer not work in a UL (which has the same Mark Levinson audio as the CL and ML)?
Old 04-23-14, 09:30 AM
drdarell
drdarell's Avatar
Default $8 sub
The UL has a cooler behind the center armrest, where the std. version has a access hole to the trunk. So that $8 speaker is just a bit too deep (1/8 or 1/4 inch) to fit in the space. There is no clearance issue with the std. model and I hear it works quite well.
Old 04-23-14, 10:29 AM
Gene01
Gene01's Avatar
Thanks for the information. Bummer.
NoneSoVile
02-25-19 09:49 PM
Ken167
12-15-17 11:27 AM
kobrapack9
06-30-11 05:28 PM
SMC
05-14-08 02:20 PM
speedie
04-16-06 08:23 PM
Quick Reply: BuZZing Sub-Woofer
