05 LS430 transmission replacement
Old 04-15-14, 03:55 PM
GoldGS3
GoldGS3's Avatar
Default 05 LS430 transmission replacement
My transmission is slipping, won't reverse - it is broken at 164K miles.
I need your advice:
Option 1: replace with Lexus Dealer refurbished transmission that comes with 1 yr warranty but costs ~$2,800
Option 2: replace with used transmission - no warranty and mileage/usage unknown, but ~$900 cheaper. Do you know a place in Los Angeles County where I can get a used transmission?
Thanks,
Old 04-15-14, 04:34 PM
1WILLY1
1WILLY1's Avatar
there are places that sell used trannies for a fair price with warrantees, just need to find them
find places that deal in imported Japanese cars and engines , there are a ton of them
time to stay home and work the internet and phone for a while till u find a good deal ,,,grind it out ,,ull get lucky eventually
Old 04-15-14, 05:58 PM
BMW7_LS430
BMW7_LS430's Avatar
Curious...did you ever change ATF or drain/refill?
These transmissions are really good. I have read only rare failures and lasting 164K itself is good.
Old 04-15-14, 05:59 PM
L8RSk8R
L8RSk8R's Avatar
Are you self diagnosing the issue, or has a shop done a diagnosis?
I have a very steep driveway, about 300 feet long. Occasionally in reverse, it slipped a little with an occasional shudder.
Took it to transmission shop and they replaced the fluid. Slipping stopped completely.
That was roughly 100,000 miles ago.
Old 04-15-14, 08:35 PM
1WILLY1
1WILLY1's Avatar
yea with my sc400,,,and many other peoples sc400's,,,,,90% of the time when the tranny was acting up or slipping we drained and refilled fluid and it resolved the issue
Old 04-15-14, 10:07 PM
damon
damon's Avatar
All the below use the A650E.
1998-2005 Lexus GS 300 (2nd Generation)
1998-2000 Lexus GS 400
1998-2000 Lexus LS 400
2001-2005 Lexus GS 430
2001-2005 Lexus IS 300 (1st Generation)
1998-2005 Lexus RS 200 (jdm Altezza)
2001-2003 Lexus LS 430
1998-2000 Lexus SC400
2001-2005 Lexus SC 430
Old 04-15-14, 11:54 PM
RA40
Super Moderator
RA40's Avatar
Has the tranny fluid ever been drained-replaced? For the sake of fellow WS tranny owners, having he fluid analyzed would provide good info on how well the additive package held up for the given miles on it.
Old 04-16-14, 04:35 AM
damon
damon's Avatar
Fluid & Filter change first is a solid cost alternative first move.
Not sure on the specifics of the Aisin Warner A650E but JDM replacements are sometimes not simple drop in alternatives. Check carefully all electronic & mechanical connections. Often there are output shaft discrepancies as well but that is an easy swap.
note: also double check for accuracy the list of possible donors I cut & pasted above!
Perhaps helpful info if you do swap: despite it arriving on a half pallet with a lift gate I could relatively easily pick up & an A341E & load it in my trunk.
Old 12-02-20, 04:03 AM
Jazaceta
Jazaceta's Avatar
what trans is in a 2006 ls430
Old 12-02-20, 05:39 AM
430SLOwner
430SLOwner's Avatar
six-speed automatic transmission A761E
Old 12-02-20, 09:35 AM
JffGRY706
JffGRY706's Avatar
always shop ebay for car parts super folks over there
Old 12-05-20, 08:16 PM
Ricklin
Ricklin's Avatar
Now that is an interesting observation.
Old 12-06-20, 11:34 AM
lextout
lextout's Avatar
The A650e is one of the most robust transmissions out there. Highly over engineered and the perfect 5spd auto.
Old 12-06-20, 11:41 AM
Midgejam
Midgejam's Avatar
Default Hard shifting
I need your advice:
Thanks,
HiI am being offered a 2006 430ls which has been driven for over a year with a hard shifting problem. Nothing has been done by the owner to resolve the problem. My question is, does driving with a hard shifting problem cause lasting damage to the tranny? If I find the issue is the ECM for example will it be potent8 good as new again??
Old 12-06-20, 12:00 PM
Received 1,146 Likes on 853 Posts
Yes it very likely would be fine
Quick Reply: 05 LS430 transmission replacement
