04 06 ls430 atf fill plug location - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 03-25-14, 09:32 PM   #16
Zodiac
Quote:
Originally Posted by BMW7_LS430 View Post
Fig 3 shows fill plug.
Fig 1 shows how to get to the fill plug by removing the cover (2 bolts)
Fig 2 shows pan with drain and overfill plugs.
Thanks for the clarification.
Zodiac is offline   Reply With Quote
Old 03-26-14, 10:16 AM   #17
Lavrishevo
Lavrishevo's Avatar
Quote:
Originally Posted by writes123 View Post
There is a filter. Metal One.
3533050020 maintenance & lubrication, transmission, transmission parts, filter
3516860010 Transmission Transmission components Trans pan Gasket 3.0 li
costs around $50
plus you'll want to replace the gasket if you do a pain and filter drop.
drain and fill
drop pan and replace filter and gasket
"flush" via engaging torque converter and transmission cooler line method.
those are the three general methods to replace the transmission fluid.
a std drain and fill uses around 3.4 quarts. dropping the pan gets a little more out.
Takes 11.5 quarts for a complete fluid exchange.
Toyota WS fluid per quart costs at least $7 per quart. If you can find a discount from a local Toyota dealer.
Lexus calls it a strainer. It's not like an oil filter. It's a metal screen and not normally serviced unless you have a reason to drop the pan.
http://www.lexussouthatlantaparts.co...sembly=1176079
Lavrishevo is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
IS250 - How much ATF drains from drain plug? shlomie11 IS - 2nd Gen (2006-2013) 4 01-04-17 01:50 PM
ES350 DIY transmission fluid change dreyfus ES - 5th Gen (2007-2012) 20 12-20-16 06:14 AM
Is there an easy way to refill the transmission? CareyPJ LS - 4th Gen (2007-2017) 24 02-17-14 09:36 AM
Fluids for the GX470? Diff, T-Case, Coolant, Brake, etc lazybummm GX - 1st Gen (2004-2009) 5 01-21-14 05:10 AM
Transmission Oil Change for 2005 LS 430 Oilguy LS - 3rd Gen (2001-2006) 7 09-11-13 02:27 PM
Tags
06, 2004, 430, 470, asembly, case, deep, dlc3, fill, gs430, gx, located, plug, stick, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
