LS430 UL (2005) Air Suspension
Old 12-25-13, 08:01 PM
boost71
boost71's Avatar
Default LS430 UL (2005) Air Suspension
Hey Guys,
Merry Christmas.
I have an LS430 2005 Ultra. I recently changed the Front Right Air Suspension and the Rear Right Air Suspension. Since the change the car is slightly tilted to the right. Is there a way to program the height of the suspensions or do I need to replace the Left sides as well?
Old 12-25-13, 11:39 PM
Lavrishevo
Lavrishevo's Avatar
You need to have the height sensors adjusted. This is most likely the culprit. The right side was leaking?
Old 12-26-13, 01:29 AM
boost71
boost71's Avatar
Yup. Both the right side suspensions were leaking..
How can I adjust the height sensors?
Old 12-26-13, 08:18 PM
ultm8mind
ultm8mind's Avatar
Supposedly on a level surface you can put it on "Hi," then once it's up, set it back to "Norm." Drive back and forth about 10 yards each time and it should get set back to "level." I also might be selling my DataSystems Controller and harness for 04-06 models...
Old 12-27-13, 12:08 AM
boost71
boost71's Avatar
Okay.. I'm gonna try that. Let's see what happens.
What can I use the DataSystems Controller and harness for?
Old 01-07-14, 07:49 PM
yeskay
yeskay's Avatar
how many miles did the original air suspension lasted before replacement?
thanks
Old 01-08-14, 08:02 AM
Lynzoid
Lynzoid's Avatar
BS... Service manual calls for adjusting sensor arms' length using values, indicated in it (manual).
Airsus will NOT self-calibrate!
Old 01-10-14, 02:52 PM
ultm8mind
ultm8mind's Avatar
Hence the supposedly, I hadn't had any issues until I responded to someone else having issues, haha. My battery died and now mine has issues, my rears are inflated and will not go down. This sucks.
Old 01-10-14, 03:03 PM
Lavrishevo
Lavrishevo's Avatar
The data system, although nice, will ruin the bags over time. I would remove the controller and reset the whole system. New battery of course.
Old 01-10-14, 03:24 PM
1WILLY1
1WILLY1's Avatar
just throwing it out there, if any of u need to replace your air suspension there is a guy in the Toronto section of kijiji selling 3 working units for $100 a piece.
Old 01-11-14, 07:53 AM
Coulter
Coulter's Avatar
Even though the air springs are expensive, I think you can make a good case for either swapping all of them out when the miles get high or converting them to a coil. I would think just the right or left side would cause issues as a shock/strut with 100k plus miles is going to perform differently than a brand new one.
And when people talk about keeping the air suspension, this is a good example that there's more to these systems than just the air bags that can go out.
ancdmd
Maintenance
03-08-14 05:24 AM
marek kope
04-16-09 05:51 PM
jcramair1
Wheels, Tires & Brakes Forum
06-17-04 06:23 PM
drink300
12-07-02 07:28 PM
Quick Reply: LS430 UL (2005) Air Suspension
