LED DRLights - Club Lexus Forums
LED DRLights
Thread Tools Search this Thread
Old 11-06-13, 10:41 PM   #1
MALYOU
MALYOU's Avatar
Default LED DRLights
I purchased LED running lights, not as a replacement to the parking lights, but as an addition.
Can I lift out the fuse box on my 2004 LS430 to gain access to the parking light fuse to connect?
Please advise how to remove fuse box.
Malcolm.
MALYOU is offline   Reply With Quote
Old 11-07-13, 04:02 AM   #2
Kansas
Kansas's Avatar
Are fuse taps available down there? I used one to install a DRL kit on our Prius v wagon ... this one.
Kansas is offline   Reply With Quote
Old 11-07-13, 04:10 PM   #3
MALYOU
MALYOU's Avatar
Thank you Jim for the quick reply and suggestion. I will check it out today.
Regards,
Malcolm.
Old 11-08-13, 11:55 AM   #4
MALYOU
MALYOU's Avatar
Dear Jim,
Thank you for solving my problem.
I have purchased a fuse tap on Ebay .
US$4.99 free delivery to Australia.
Regards,
Malcolm.
Old 11-09-13, 06:10 AM   #5
Kansas
Kansas's Avatar
Great! I'm glad I could help. One more "trick" of using fuse taps in an engine compartment fuse box is to fish the wire you want to connect to the fuse tap up from an existing opening in the bottom of the fuse box rather than notching the plastic fuse box cover or housing and potentially allowing water to enter through the notch.
My favorite "tool" for fishing wires like this short distances into fuse boxes, through car doors, etc. is a 12 inch flexible plastic cable tie. To illustrate, the attached photo shows my Prius DRL wire kit yellow "hot wire" coming up through an existing opening in the bottom of the Prius fuse box. My 2000 LS400 fuse box has similar openings at the bottom of the fuse box and I suspect that most Toyota engine compartment fuse boxes also do.
Old 11-11-13, 01:34 PM   #6
MALYOU
MALYOU's Avatar
Dear Jim,
I did intend to pull the wire up through the bottom of the fuse box. The LS430 box does have a small entry in the base. Thank you again for your info and intrest .
Regards,
Malcolm.
Thread Thread Starter Forum Replies Last Post
Interior light mod? heybro GS - 2nd Gen (1998-2005) 6 03-09-17 10:38 PM
GS400 footwell light issue BrotherAli GS - 2nd Gen (1998-2005) 0 06-27-16 09:40 PM
What kind of fuses does a 2013 Lexus ES 350 use? AdamKralic ES - 6th Gen (2013-present) 3 11-28-15 03:56 PM
10 Amp fuse keeps blowing out after installing LED parking lights(HELP!) brianskiim IS - 2nd Gen (2006-2013) 1 05-19-15 04:29 PM
Replaced parking lights-fuse issue 642jdub GS - 3rd Gen (2006-2011) 2 02-21-15 12:52 AM
Tags
drl, hot, lexus, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
