Rotors
Old 10-17-13, 07:36 PM
jaywish
jaywish's Avatar
I must say that usually I do not cot rotors when doing brakes. If there is definite brake vibration I replace the rotors otherwise just replace the pads and any related hardware and seals as necessary.
I do not know if the lexus service manual even recommends cutting rotors, some manufactures do not.
I generally get good results with this process.
Old 10-18-13, 04:38 AM
AlexusAnja
AlexusAnja's Avatar
If there is no shaking or shimmy when braking, there is no reason to cut rotors. Why shave material off equating to maybe tens of thousands of usable life off. I've never in 25+ years of vehicle ownership ever cut rotors.
Old 10-18-13, 06:24 PM
jmsmiff
jmsmiff's Avatar
I don't get any shaking in the steering wheel, but when I brake it's the worse sound I've ever heard.
I figured it was the eBay drilled/slotted rotors so I figured I'd go back oem. Guess I used to driving the Acura which could use those type of pads and rotors. So should I try the new pads first before scrapping the rotors or just replace everything?
Old 10-18-13, 07:02 PM
jaywish
jaywish's Avatar
This kind of remote diagnosis is difficult but if it is 'the worst sound you ever heard' my guess is something is wrong. By that I mean something was not installed properly or has failed.
Did you do the install yourself? Do you have the equipment and inclination to see what is wrong ?
Old 10-18-13, 07:04 PM
jaywish
jaywish's Avatar
Do the rotors you installed have a right and left? Do the pads have an inner vs. an outer?
Old 10-19-13, 12:35 PM
UZ214
UZ214's Avatar
stay away from ebay rotors pads, if you cannot get the stock setup, go with OE similar like brembo rotors but always ceramic pads. not with that semi metallic crap
Old 10-21-13, 09:32 AM
Lynzoid
Lynzoid's Avatar
^^^^^^^ That.
this is lexus ls, not saturn cheap
Old 10-21-13, 06:41 PM
BMW7_LS430
BMW7_LS430's Avatar
How do you feel about Wagner rotors?
Old 10-21-13, 07:32 PM
jaywish
jaywish's Avatar
Never had a problem with the Wagners.
Old 11-13-13, 12:26 PM
jmsmiff
jmsmiff's Avatar
Decided to go with an OEM set of rotors and I'll try out some posi quiet pads and see how they go.
Old 11-13-13, 02:13 PM
HRDBDY808
HRDBDY808's Avatar
i used avic for my brake pads and they runs smooth . i talked to some parts guys and said they are exactly oem just different box.
Old 11-23-13, 05:27 PM
jmsmiff
jmsmiff's Avatar
Replaced them with oem rotors and pads, I also found the slide bolt that holds the pad was falling out. Pulled all the brake pads, they were about 75-80%. No more shaking Car rides like new.
Old 11-25-13, 08:01 AM
jaywish
jaywish's Avatar
The "worst sound you ever heard" was probably the loose bolt.
PTYIS2
IS F (2008-2014)
02-13-18 09:07 PM
chris6878
IS F (2008-2014)
05-05-11 06:07 AM
GREENDAY
12-16-10 05:53 AM
stiles_s
GX - 1st Gen (2004-2009)
06-30-09 06:50 AM
Quick Reply: Rotors
