side view mirror light in-op
light is in-op. i was replacing the oem light with led . i did the credit card method but putting it back was a pita. doing that way made me strip the wire. so wat i did was pull apart the whole mirror and check if there was anything else that was strip and reconnected it with a connector and heat shrink it. i have power to two wires. coudl it be the light bulb socket? it wierd i put the oem light in and it would go on . but the led light would go on however in the lock mode not the unlock mode. im in need of help i have no other choice but to change out the bulb socket. any ideas cl members.
Limpart
24
10-24-08 02:18 PM
