Headlight washer on left side not working
Old 01-11-13, 12:06 PM
Ls430Tom
Ls430Tom's Avatar
Default Headlight washer on left side not working
Hi, I'm in Ireland and have a 2001 LS430, spec should be same as over there except a couple of minor changes like the wheel is on the other side .
On the left side, (your drivers side) the headlamp washer is not working, right side is working fine. I can hear noise on the left side but I am assuming it's the pump, when the switch is pressed there's no movement at all from the left side.
Could there be a blockage within the actuator or has the actuator failed? Has anyone got any ideas what it could be, a replacement actuator is quite expensive and not easy to get as a used part. Is there an alternative Lexus model that shares the same actuator which might be easier for me to source the part?
LCInfrared
05-21-18 01:49 PM
snakehead
02-20-15 06:55 PM
supralative
11-05-12 06:27 PM
100mgbluep
SC- 1st Gen (1992-2000)
02-09-08 08:22 PM
Wald GS
GS - 1st Gen (1993-1997)
06-01-03 04:00 AM
Quick Reply: Headlight washer on left side not working
