Want to change wheels LS430
What wheels will fit my LS? I have a GS as well and put the wheels from my SC400 on it. Will wheels from other models fit the LS430 ? I want to go to 17" chrome. I know the big calipers on the LS are a problem. Help, want to do this on the cheap!
You can check out some options here: http://www.oewheelsllc.com/Wheels_3/Wheels-for-Lexus
I've bought three sets of rims from them and the quality is good. Others on here have bought them as well... Cost for four rims is equivalent to a single OEM rim...
Super Moderator
This carries over to the 430, what we've found:
-OEM Lexus wheels that fit 95-00 (5x114.3, 60.1mm hub)
95-00 LS400
01-06 LS430
06-11 ISX50
06-07 GS430
07-11 GS460
LS460 wheels do not fit They are 5x120 and will need an adapter.
You can also consider Nissan (May the Toyota God not strike your car down at the thought) wheels from the G series coupes, I don't know if any of us have tried wheels from the G sedan. The hub bore is different so you'll need hub rings.
95-00 LS400
01-06 LS430
06-11 ISX50
06-07 GS430
07-11 GS460
Seems that RA40 has given a list of wheels that will fit a '95 - '00 LS400 ....
Will '02 - '03 GS 17" wheels frit a 2005 LS430 ?
I thought if you want OEM wheels for an LS430, that ONLY wheels from an LS will fit an LS, and the other Lexus wheels will not clear the front calipers. Am I correct ?
