how do you know if it will compromise the lug nut seating area??
I personally don't know. I would leave it up to the expertise of an experienced wheel modifier/machine shop. Let's say your lug nuts seat inside the holes and there is 10mm from that seating area to the back of the pad. If you shave down 5mm, then the remaining 5mm of metal may not be strong enough to hold everything. The exact amount that is safe is an unknown number to me.
Originally Posted by sojah
also if i am presently at a good riding height were i only rub (front) when turning the wheel very sharply and hitting bumps, or if someone heavy is sitting on the passenger side (200 or more lbs) and i turn into a driveway, if i take off 5mm from the back pad (front) does this mean i can only go 5mm lower?? i'm hoping that 5mm is the secret number to where i can go say a half inch lower in the front and do the same in the rear also. but i guess there is no way of knowing until i try it out and see huh???
I can't say for sure, as your suspension has several different components and is not exactly linear in nature. Personally I would just mod fenders instead of shaving your wheel pads. Much easier and more predictable.
sorry for thread jacking but i noticed that gato had this done on his wheels so i was hoping to get some good info about doing it on mines.
You can try PM'ing him.
the fenders are modded, i guess running a smaller tire which is something i'm trying to avoid is the best thing to do. thanks for the responses...
i wish the rear would seat a little lower to match the front so that the car level. not sure if it is just the picture the exhaust tip looks like the left is seating higher. other than that i think it look sweet.
