anyone got LED Daytime running light?
Old 03-29-11, 05:05 PM
calboy76
calboy76's Avatar
Red face anyone got LED Daytime running light?
i searched online and on ijdmtoy.com. can't find led light for my lexus ls430 daytime running.
anyone can help? i like to get a set that gives me no trouble or computer error code
thanks!!!
Old 03-29-11, 05:09 PM
CarGuy89
CarGuy89's Avatar
I've yet to see it on an LS430. I suppose you could copy what Merc does and place them by the fogs. Or you might be able to put them inside your headlight cover (saw it on a modded LS460). Don't really know where you would find such a thing
Old 03-29-11, 05:40 PM
HiloDB1
HiloDB1's Avatar
You mean a replacement LED bulb for you DRL/High Beam?
V-Leds has a kit. But they are just 9005 bulbs. So almost any 9005 LED should work. Only thing is you loose your High Beam function.
Here is a thread on the V-Leds setup.
https://www.clublexus.com/forums/lig...8-led-drl.html
Rubenm (06-17-20)
Old 03-29-11, 07:58 PM
CarGuy89
CarGuy89's Avatar
I thought you meant something from the new Audis.
http://1.bp.blogspot.com/_B6XJ2t9gUa...udi+scaled.jpg
If you are just talking about swapping the existing DRL lamp with LED lights then that is a pretty common thing here (and it looks awesome). It's on my 'want' list but the headlights are quite difficult to take apart.
Old 03-29-11, 11:14 PM
Vpanin
Vpanin's Avatar
Wow.......loosing the highbeams would suck in NYC..........i dont know about you guys. I love those day lights in the pic though
Old 03-30-11, 02:25 AM
So Philly1
So Philly1's Avatar
Like this??
DRL stock on the left....LED on the right!!! Trust me it looks alot better!!! You just lose your high beams..
Old 03-30-11, 06:08 AM
GeorgeT
GeorgeT's Avatar
I would just like to turn the damn things off.
Old 03-30-11, 07:42 AM
Sentinel
Sentinel's Avatar
Why do you loose you high beams?
Old 03-30-11, 09:40 AM
Tee
Tee's Avatar
Loosing your brights is not a bad thing, I re-aimed my headlamps up higher due to them being aimed low by the factory and have no need for high beams. The 430's projector HID's are incredible for light output and road coverage (Better than the 460) you won't believe (check out the pic below)
As you can see they are very capable and the most sought after projectors that are retro fitted in other vehicles, I did not miss the brights at all. Quite a few guys here have done this mod as well, just another option I'm putting out there.
Here are some pics I took after I put in brand new HID bulbs in my 430.
For you guys that want to know how to raise the 04-06 low beams.
1st- You will need a ratchet & a 10mm socket
2nd- Park on a flat surface in front of wall with headlights on.
3rd- Behind each low beam headlight there are holes, stick the ratchet socket into the hole and turn clock wise to raise to the desired height. This will also adjust both low and high beams at the same time, do not go nuts or it will be too high! A few turns should do it, start out slow.
4th-Test drive, if you don't like adjust until you do, if you do like say "CAKE" and you are done
B/c the LED's do not output enough light to be useable for hi-beams.
Old 03-30-11, 09:59 AM
sojah
sojah's Avatar
thanks tee, i couldn't have said it better if i would have even tried
Old 03-30-11, 10:56 AM
DDLexus
DDLexus's Avatar
any error message on the instrument panel after the simple bulb swap (factory > LED)?
Old 03-30-11, 11:23 AM
So Philly1
So Philly1's Avatar
nope...basically just changing a bulb
Old 03-30-11, 02:13 PM
sojah
sojah's Avatar
if you use the vled kit i think you need a little plug and play inline converter thing don't you?
Old 03-30-11, 02:21 PM
HiloDB1
HiloDB1's Avatar
Yeah if you get the kit it comes with the little inline box. It has nothing to do with warning lights on your dash AFAIK
Old 03-30-11, 02:24 PM
Sentinel
Sentinel's Avatar
so why do you loose your high beams?
Quick Reply: anyone got LED Daytime running light?
