DIY Timing Belt Change
I will be changing my timing belt in the next month. Instead of turning the cams and crank until all of the marks line up why can I not just put the new belt on in the same spot as the old one? The cam gears have a mark on them that the lines on the belt line up with. As long as the gears don't move after the old belt comes off and the new belt goes on with the lines on the cam gears marks what is the problem? This would eliminate turning the gears which is a pain unless you remove the spark plugs.
Thanks.
Thanks.
Thanks.
Thanks.
Andrew
Valencya01
Maintenance
10-30-18 08:02 AM
mooseboy84
10-31-15 11:35 PM
