LS 430 Door Lock Actuator Tutorial - Page 7 - Club Lexus Forums
Thread Tools Search this Thread
Old 12-01-12, 01:56 PM   #91
69charger
Quote:
Originally Posted by rael View Post
Same here, 4 doors, 3 hours. I started at the rear driver door, then rear passenger, front driver, front passenger. Seems odd that they were all acting up at once, but $17, 3 hours and no blood or cussing--which is amazing for me.
On the first one, I pulled the screw out of the door striker which was a mistake as the spring took off. I got it back together fairly easily though. I think I had the last one done in 25 mins. with 8 mins of filing the shaft. I used a small hobby vise on the disassembled motor. I was just going to use the old shaft and winding but too it did not fit quite right, the shaft had a large thing where the brushes connect. I also had trouble with the zip ties as they interfered with the plastic shrouding, so I used glue.
Overall a very satisfying project. Thanks OP. I was thinking about dumping the car as I am now at 150K, but I just can't justify it as it is still in near perfect condition.
I need to file my actuator shaft to a "D" shape, how did you keep the shaft from spinning freely while filing.
69charger is offline   Reply With Quote
Old 12-03-12, 01:26 PM   #92
Becker135
I did it with a pair of needle nose pliers......
Becker135 is offline   Reply With Quote
Old 02-03-13, 02:53 PM   #93
SML1998
Default Replaced the actuator motor; lock not fixed
I just took a stab at this... completed the project in just over 2 hours. But I guess I can't say "complete" unless it fixed my problem.
My front, driver's side door still doesn't lock/unlock with the remote. In fact, none of the doors will lock unless I first lock the driver's door manually; then the other three doors will lock with the remote. Same is true when unlocking. I was REALLY hoping that replacing the motor inside the actuator was going to be the fix... perhaps I did something wrong? Or is there something else I should look at?
Now that I've removed and installed the actuator once, I'm sure I can do it again in less than an hour.
SML1998 is offline   Reply With Quote
Old 02-03-13, 03:03 PM   #94
SML1998
Default Actuator motors
Although my door lock problem was not resolved by replacing the actuator motor, I would like to share with the group my source for the motors, the part number and how easy it was to file the shaft. I read a lot of comments about swapping motor parts to preserve the original "D" shaft... grinding the shaft on the motor was super easy. Of course, you must own or have access to a grinder. If you don't, I recommend buying one. Think of the money you're saving from tackling this project yourself and apply some of that saved money towards a grinder or a dremel. These tools will pay for themselves many times over!
Here's the ebay auction and part number:
4 pk MABUCHI CAR DOOR LOCK MOTORS - DIY ACTUATOR REPAIR Toyota Lexus Honda Ford
http://www.ebay.com/itm/4-pk-MABUCHI...34ae58&vxp=mtr
Manufacturer Part Number: FC-280PC-22125
Interchange Part Number: FC-280PT-22125
Other Part Number: KF243G-101
SIZE SPECIFICATIONS:
Shaft: ROUND - 2mm diameter x 9.85mm length
Canister: 24.2mm Diameter (18.3mm on flat sides) x 30.5mm long
Overall Length: 45.0mm (Tip to Tail)
Old 03-13-13, 10:30 AM   #95
mikethevik
Thanks for the info...I might give it a try!
mikethevik is offline   Reply With Quote
Old 03-13-13, 12:02 PM   #96
SML1998
Default Door Lock Resolution
After giving it the 'ol college try to repair my lock by replacing the cheap little motor (didn't work for me)... I ultimately purchased a NEW actuator from an online parts dealer. Cost ~$220 or something like that. Total installation took ~45 minutes since I had already performed the ritual once before. Problem solved. I think the original contributor to this thread did the same thing. All door locks are now functioning and I'm happy. Just wished I could have solved the problem with a $4 motor, instead. Good luck to anyone attempting this repair and THANK YOU to everyone who has contributed to this thread.
Old 03-14-13, 07:57 AM   #97
SQuester
SQuester's Avatar
Did you dig into the old door lock actuator assembly to see what the fault was if the motor itself wasn't the culprit?
SQuester is offline   Reply With Quote
Old 03-27-13, 08:19 PM   #98
ccm241
Quote:
Do you have a link to where you purchased part?
ccm241 is offline   Reply With Quote
Old 04-21-13, 11:42 AM   #99
DesertLS4
DesertLS4's Avatar
Thanks for the sticky! I have the auto door closers so it was a little different but who can complain about a 5 dollar fix? My mechanism is held back together with screws so I didn't reseal.
I've had to do this on my GS and daughters Celica too.
Still love Lexus.
Mike in AZ
DesertLS4 is offline   Reply With Quote
Old 04-22-13, 02:14 AM   #100
BMW7_LS430
BMW7_LS430's Avatar
Still love Lexus.
Mike in AZ
I have auto door closers and need to fix driver side door. What are the differences?
BMW7_LS430 is offline   Reply With Quote
Old 04-23-13, 03:31 PM   #101
DesertLS4
DesertLS4's Avatar
Quote:
It's a pain in the nads to get back in. The assembly is 3x the size of the ones in the pictures. Note how the window track comes out of the way(towards the door hinge) so when you put it back in you can do the same.
Mike in AZ
Old 05-28-13, 11:43 AM   #102
jenkins000
Default Door stuck closed after attempting DIY
So I went ahead and bought the recommended motor off of ebay. After drilling out the older plastic gear so that the 'round shaft' would fit, I epoxied it together and made sure it spun. Then I reassembled everything as best as I could remember and made sure the wireless fob could activate the lock. It did, no problems there. But then after closing the door, I am unable to open it again (from the inside or outside). I get no resistance from the door handle.
I was able to remove the inside panel partially with the door closed and I can reach in and grab the gold rod. But even after moving it up and down, no luck. Also, pulling the lock/latch lines that connect to the interior handle/lock, does nothing.
Any advice for getting the door open? I think I can rework it once I get it open.
Thanks
jenkins000 is offline   Reply With Quote
Old 05-28-13, 03:54 PM   #103
Bon
Ugh! Maybe someone with a slim jim can get the latch to release. Maybe not. The following is how I got into trouble and got out of it like you. The slim jim wouldn't work for me and I couldn't get my LX470 rear interior door panel off with the door closed.
I haven't (yet) performed the repair on my LS but I did my LX this past Winter. I hate to admit it but I put the latch mechanism back together wrong and shut the door as you did. In the case of the LX there was a little nylon piece that was temporarily removed and I put it back on the wrong way. Same problem: The latch wouldn't release either from inside or from the outside of the car. Big problem! I don't know why I didn't test the latch before shutting the door - brain fart - I guess. Next time be sure to test the latch using a screwdriver tip to close the latch and make sure that the inside and outside handles can release it (I guess that you know that by now )
Okay, this is what I did. I removed the interior panel that is just behind the door. This is on the inside of the "B" pillar. This where the seat belt rolls into. From there I used a Dremel tool and an air cutter to cut through the two nuts that hold the latch to the B pillar. It was not fun work but once done I just pushed the remaining screw stubs out of their holes and the door, with it's latch swung free. By inspecting the other side door I was able to see where a short length of coat hanger wire was able to release the latch from the door. I bought two new bolts and Nyloc nuts from the local hardware store and I was back in business for less than $5. Peeking into the B pillar should tell you what you're in for should you try something like this.
Bon is offline   Reply With Quote
Old 05-30-13, 07:12 PM   #104
jenkins000
Thanks for the input Bon. At first I was kind of confused by your directions... I was looking for those 'two bolts' everywhere. But I believe you're referring to the rear door, right?
Unfortunately, the front door can't be clipped like that.
I think my next order of business is going to be cutting through the striker bolt.
It's a U shape and screws into the body of the car. But if I can get a dremel in there... I might be in luck.
I'll let you all know how it goes.
Old 05-30-13, 07:51 PM   #105
Bon
Did you remove the B pillar interior trim and look? I'm not saying that I know that you can access them from there but I'm curious if you looked and if there is an opening to see the striker nuts. The nuts are welded to a backing plate so they don't spin. The plate is tack welded to the sheet metal of the B pillar. I don't see how you can access the striker with the door closed because the door and B pillar block you.
I know my previous description was confusing. I was attempting to blend what I did to my BACK door on my LX and how you might approach your front door striker bolts/nuts through your B pillar.
Thread Thread Starter Forum Replies Last Post
$26 diy VS $1,800 at the dealer. Door lock actuator Alex818 SC430 - 2nd Gen (2001-2010) 22 01-25-17 06:44 AM
RX330 Door Lock Actuator DIY JamesInJax RX - 2nd Gen (2004-2009) 15 01-03-17 07:45 PM
LS430 Door Lock Actuator bnguyenz LS - 3rd Gen (2001-2006) 11 09-14-16 03:08 PM
I seem to have broken the motor for the door lock actuator fatlouis RX - 1st Gen (1999-2003) 1 11-29-15 04:20 PM
2005 LS 430 Easy-Close Drivers Door Lock Actuator hklinker LS - 3rd Gen (2001-2006) 23 02-19-15 10:09 PM
Tags
04, 2004, 430, actuator, club, door, is300, lexus, lock, ls430, ls430door, mabuchi, motor, problem, solenoid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
