Old 12-16-14, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
HOW TO: LS430 Interior/Exterior Lights/LED w/Pics & part#s
Old 07-07-10, 12:46 PM
Boomer01
Boomer01's Avatar
Great job!
Old 07-11-10, 01:35 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Great job! Thats going into the FAQ thread.
Edit: Looks like someone beat me to it, thanks votru!
Old 07-12-10, 09:22 AM
votru
votru's Avatar
Grand LS4.....no problem at all, glad I can help.
RomanTPA.....can we change the light in the glovebox or armrest middle console? The amber light not very bright when looking for junk that I have in there , thanks.
Old 07-12-10, 11:16 AM
RomanTPA
RomanTPA's Avatar
yes, i think its the same bulb thats in the ashtrey. thats on my next thing to do when i get some free time.
Old 07-14-10, 04:25 AM
RomanTPA
RomanTPA's Avatar
(!) Just got an intresting idea (!) Write up shall follow soon
Old 07-14-10, 12:15 PM
Dr. Jekyll
Dr. Jekyll's Avatar
Great write up! Thanks for taking the time to post this. I'm sure a lot of people appreciate it.
Old 07-15-10, 05:42 AM
RomanTPA
RomanTPA's Avatar
^ Thank you
BINGO !!!
You guys gonna love me!
Just found ALL bulb numbers!
Please check beginning of 1st post
Old 07-23-10, 11:55 AM
RomanTPA
RomanTPA's Avatar
added all locations ob lights in the car with #s
Old 07-24-10, 03:52 AM
motohide
motohide's Avatar
Smile You forgot the Switch Clusters ~~ :)
Nice Work!
Here's what I did using a little soldiering using 1w 12V LED singles by modding the socket base and removing the filament bulb and replacing it with LED.
No more green and and in place, a nice cool white color switch in the night time.
You can also make them glow orange like an AUDI simply by removing the 'condom' green caps off these filament bulbs too, but I just took the extra step and glued some LED's in place.
kos (02-27-19)
Old 07-25-10, 07:31 PM
RomanTPA
RomanTPA's Avatar
thats on my to do list also, but i just dont have time to mess with the 1000 switches/lights that are in that car.
btw what lens are you using in the second pic?
Old 07-26-10, 04:58 AM
motohide
motohide's Avatar
If it meant the actual photo itself, its taken with a Nikon D90 SLR with Tamron 11mm-18mm Wide Zoom.
Edit: Opps... Upon checking again it was my Nikon 18-200 VR lens. Sorry.
Old 07-26-10, 05:45 AM
RomanTPA
RomanTPA's Avatar
vr is nice too bad i cant afford it =(
i have a 28-300 tamron on my d100
Old 07-26-10, 02:02 PM
mrsandman
mrsandman's Avatar
Glove Box, Center Console, and Door/Window Switches
The glove box (upper and lower) and center console each have 3 chip SMD LEDs on a single circuit board that light up amber in color. These can be replaced by soldering in different color chip SMD LEDs (like super bright white). The size of these chip SMDs is 1206 (0805 will work also, but they are quite smaller than 1206). The switch light that light faint green can also be replaced by soldering new chip SMD LEDs, in which these leds are also mounted on a circuit board. The size is also 1206.
You can purchase these LEDs at lc-led.com
I have used the 0805 chip SMD LEDs super bright white at 250mcd, though the correct size is 1206.
Inner Door Handle Lights, Driver/Front Passenger Footlights, and Upper Center Console Lights (those 2 lights that shine above the shifter)
These also require soldering. The inner door handle lights and footlights use 3mm LEDs bulbs and the upper center console uses 5mm LEDs.
You can purchase these LEDs at superbrightleds.com
I have used the 3mm LED super bright white at 6000mcd, 45 degree and 5mm LED super bright white at 8000mcd, 45 degree
Garage Door Buttons and Memory Seat Buttons
These were also replaced with the same method as above using the same 3mm LED bulbs super bright white replacing the faint green LED. Each number requires its own bulb.
Upcoming Mods
If anyone is interested, I am working on changing the green and amber lights of the front driver assembly (the green light on the coin tray, switches, and such), steering wheel control lights, the lights that motohide had done, and even the climate control.
Logansully (10-30-21)
Old 07-26-10, 02:28 PM
motohide
motohide's Avatar
I don't see anything wrong with using non-OEM Nikon lenses at all. If the price is right I'd like to get my hands on the Tamron 18-280, as I'm not too critical of fringe distortions as much as getting the right photo at the right moment. And, less changes of the lens, the more quickly I can do this and not miss stuff.
Your Tamron 28-300 will accommodate a full frame FX format camera too so I'd hold on to that.
Getting off-topic though, so I'll stop here LOL!
Old 07-26-10, 02:32 PM
motohide
motohide's Avatar
Upcoming Mods
Great Information!!!!! That was what I was looking for a while back!
Quick Reply: HOW TO: LS430 Interior/Exterior Lights/LED w/Pics & part#s
