moistue and water in my headlight..need help
Old 12-06-09, 04:33 PM
03 LS 430
03 LS 430's Avatar
Angry moistue and water in my headlight..need help
whats up peoples..
I got a problem thats needs to be addressed.i want to take out my headlight and reseal it.. but dont know how to do it..i put the heat gun to the lens to dry it out twice and the moisture returned.im tight cause the head light looks like its been crying. and my hid aint shinin threw like it should.. a blue print will do me good..thanks a mill.
Old 12-06-09, 11:18 PM
TJW98LS
TJW98LS's Avatar
For starters, unbolt the 2 10 MM screws that hold it in place. Without removing the bumper you MUST pull it out through the headlight hole. I've done it, but it takes some time. I suggest putting a microfiber towel or other guard on the bumper so you do not scratch it upon removal.
Old 12-07-09, 07:39 PM
bigcory
bigcory's Avatar
Have you switched out the bulbs at any point? There is a big white colored plastic piece that comes off the back of the head light. This is where you access the bulb from. You leak is probably coming from there, especially if you have changed the bulb. Bascially there is a rubber "o" ring that seals it up.
Very possible it's something else, but this would be the first thing I'd take a look at before going to all that work.
Old 12-15-09, 02:04 PM
03 LS 430
03 LS 430's Avatar
yeah i checked all dat..i recently changed the small bubs dat give off a soft light when u switch to tail light...i checked everything n found out my leveler was loose,i messed around n took it off to dry out the lens and now my aim on the right side is n sum body back window,,lol,,the leveler stills works but is un even..i now i can fix it but need clues on how to pen piont things..thanks pal....
Old 12-15-09, 02:10 PM
03 LS 430
03 LS 430's Avatar
all of dat,,,lol nah man im gud...it can be a serious project that i may regret sincerly..thanks thought it was more simple
mandyfig
12-29-14 10:30 AM
NickTomsyc
06-06-11 12:52 AM
mr29rose
SC- 1st Gen (1992-2000)
06-13-07 09:11 AM
vdt04452
12-30-06 09:40 PM
iNdoMeX
Lighting
07-20-02 07:47 PM
Quick Reply: moistue and water in my headlight..need help
