Mirrors no longer adjust
Old 04-01-11, 06:39 PM
  #31
new2lexus2
new2lexus2's Avatar
Default Another switch fix option
I had previously cleaned the switch to get mine working again and then both sides stopped working (the auto adjust worked) so I knew it was the switch again...took it apart and the problem was the plastic mounts that the two little screws that hold the switch together had cracked and the internal contacts were loose, not dirty.
The mounts were so brittle they cracked off so did not even try gluing. I took 3 small nylon tie wraps and strung them together thru small holes I put in the outer mount plastic and tightened them to hold the switch tight together....works just fine.
Attached Thumbnails Mirrors no longer adjust-imgp1841.jpg   Mirrors no longer adjust-imgp1842.jpg   Mirrors no longer adjust-imgp1843.jpg
The following 2 users liked this post by new2lexus2:
DriftMnky (03-16-22), williamcc (06-22-17)
Old 07-02-11, 06:57 AM
  #32
skassamali
skassamali's Avatar
My 05 LS is doing the same thing. What do you guys suggest I use to clean the contacts with? Q-tips and any specific chemical? Anyone have pics of this procedure on an 04-06?
Old 07-03-11, 09:41 AM
  #33
focsle
focsle's Avatar
Same as above for yours. Should be no problem.
Old 07-03-11, 10:10 AM
  #34
skassamali
skassamali's Avatar
Sorry for my ignorance, but once I pull the unit out, how exactly do I clean it?
Old 07-04-11, 03:55 PM
  #35
upendra
upendra's Avatar
Thank you for this thread. I would have spent a lot of money for just cleaning the terminals. My Right side mirror was stuck and I was told taht I may nee dto change the switch or the mirror. Tahnk God I did not get it replaced. After seeing this thread I pulled the mirror switch panel. The connector was not in completely with some play. I pulled it out cleaned the terminals and put it back. The mirror is back to action. Hope it will stay like that.
Old 07-06-11, 04:46 AM
  #36
skassamali
skassamali's Avatar
Do I just clean out the terminals with a qtip? Do I need to use any type of solvent? dor just make sure all the connections are tight and there is dust?
Thanks in advance.
Sajjad
Old 07-06-11, 07:27 AM
  #37
skassamali
skassamali's Avatar
Nevermind. I need to learn to read a little closer. One of the first posts says it quite clearly: Q-TIP AND CONTACT CLEANER . I'll try it this weekend or next and report back.
Old 07-06-11, 12:06 PM
  #38
JonHsiung
JonHsiung's Avatar
Totally doing this tonight! Thanks guys.
Old 07-07-11, 05:44 AM
  #39
skassamali
skassamali's Avatar
Success! Fixed my mirrors last night! Thanks everyone!
Old 07-10-11, 01:13 PM
  #40
pff1234
pff1234's Avatar
message numbers;12-15. My outside mirror will not retract or open all the way. It goes so far and stops and just "click,click,click" Passenger side mirror works fine. I have removed the control panel but that does not change things. Any thoughts?
Old 09-22-11, 01:36 PM
  #41
smm3
smm3's Avatar
This worked for me too. I was experiencing the intermittent mirror adjustment problem. Thanks for posting the directions and pics. Its very straight forward and saved me some money!
Old 09-22-11, 03:09 PM
  #42
Jabberwock
Jabberwock's Avatar
If the switch looks clean and is fully operational, then the mirror is likely bad. It is an expensive part - approx $600 to replace. Definitely a rare weak spot on these cars.
Old 09-22-11, 03:14 PM
  #43
motohide
motohide's Avatar
Drifter tech! haha~~ joke. Zip-Tie, or Tie-Wraps as we call in Japan, solves 10000 issues on cars!
Old 09-30-11, 07:43 AM
  #44
DLLawrence
DLLawrence's Avatar
Default Wow- thanks!
Man, am I glad I found this forum. Our local dealer wanted $760.00 to replace the driver's side mirror for this symptom. Took it apart,cleaned everything up, works perfect- This thread rocks. Thanks, guys for posting pics!
Old 10-06-11, 07:44 AM
  #45
Jerryw74
Jerryw74's Avatar
Wow - this was great and an easy fix. I had given up on the mirror and wasnt going to pay to fix it but I followed the intructions and the pics above and BAM it worked. Thanks!!!
Quick Reply: Mirrors no longer adjust
