Gauging Interest - KSport Airtech Suspension kits for the LS430
Former Sponsor
Hey,
I recently became a vendor on CL and noticed that a bunch of LS430 members messaging me about the KSport Airtech Suspension kit for their LS430's. I have had to keep turning them away, but after persistent pestering, I have had KSport come up with a solution for me. I know it is asking a lot from the LS430 owners, but here it goes:
If I can get a solid 10 members (with deposit - amount TBD) to sign up for a kit, they will start production of the kit. If you know any other LS430 owners (not on CL) who would be interested, please forward the thread on to them too. My typical pricing on KSport kits is around range between $2,500 and $3,000 shipped, for the basic and pro, respectively. With 10 kits confirmed, I will be able to offer at a better price, but this will be determined at the time of order.
Check out http://ksportusa.com/asp/air_suspension.asp for more information on their kits.
Sign your name to the list below for interest.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
See the YouTube video link for the KSport Airtech Suspension kit (pro model) in action on my 2GS.
http://www.youtube.com/watch?v=jVWbigfnsjQ
Shoot me a PM for pricing information on the kits (please type LS430 in the message header so I can continue to gauge interest).
Thanks,
Chris
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Thanks,
Chris
sounds too good to be true. so not only can you adjust the height (rather quickly) you can adjust the damper, stroke, and compression all on the fly while driving or sitting with a fairly less complex install than most aftermarket systems, all for around 2500-3k... this should be on the discovery channel pitch men show...
so whats the catch?? i wish i would have known about this last year and i would have saved 8k by not buying a UL and slapping on the datasystems controller.
how would it work if you already have the air susp UL setup?? how long should this kit last? and what is the difference between the regular and pro kits?
lastly, ls430 is not listed on the model list for these kits on your web page you linked above... hmmmm???
We have very limited choice of after market air for LS (UAS or Air Runner). After getting a bit annoyed by OEM air suspension act on its own, I am seriously interested going aftermarket air.
UAS' price is much cheaper than Air Runner but need to get separate suspension kit (which I don't want to bother), the other option, Air Runner is all inclusive but bit pricey at $4K+ (at least better than the original Air Runner in Japan "Air Bomber" which costs like $6500-$7000). Plus, my friend who has air runner on other model said the ride is pretty stiff...
$2500-$3000 is very good price I think, I just don't know much about the Ksport brand.
Anyone has more input for Ksport?
Saw a lot of good comments on Ksport group buy thread for other models.
To the OP, as others said above, I am interested.
Former Sponsor
I wish I could tell you there was a catch, but thanks for pointing out all the benefits, LOL. Next time I am down in MD (July 5-11th), you are more than welcome to ride in my KSport equipped GS to see how the ride is like, check out the components, and such.
I believe if you have the UL, it is practically like switching out the air to coilovers, aside from running air lines, power wire (for the compressor), and other miscellaneous wiring.
The LS430 is not listed because they do no currently make the kit. What I am attempting to do is get KSport to manufacture the kit (I need 10 people). This is a big step to getting a very reasonably priced product out there that will perform amazing.
Thanks for the interest,
Chris
Former Sponsor
Here's what you would get in the Basic and Pro kits, both would come with a one year warranty by the manufacturer, DEALING WITH PEOPLE IN THE USA:
Basic:
1. 1 – 5gal air tank 9 port
2. 1 – Viair 380c compressor, 200psi 100% duty cycle
3. 1 – 200psi pressure switch
4. 1 – Silencing base plate
5. 2 – paddle valve switch
6. 1 – 200psi dual needle gauge
7. 1 – Bracket for gauge and switches
8. ¼” high pressure air line
9. Power Wire
10. 1 – Fuse Box
11. 4 – Full Struts with adjustable lower mount, aluminum top mounts, and 36 levels of damping adjustment
12. 4 – High pressure airbags
Pro:
2. 2 – Viair 380c compressor, 200psi 100% duty cycle
5. 2 – electronic switches
9. Power Wire
10. 1 – Fuse Box
13. 4 – electric Solenoids
14. 2 – ¼” Valves
15. Wireless remote control
Basic:
9. Power Wire
10. 1 – Fuse Box
Pro:
9. Power Wire
10. 1 – Fuse Box
14. 2 – ¼” Valves
yes i would like to check it out when you are out here. what parts or parts of md will you be in or near, i live in annapolis but work outside of baltimore so i usually cover from about 95 to the bay bridge...
