UL stock air suspension to steel springs conversion infos
#93
I should have it on the car by next weekend.
On theory yes, a stiffer rear suspension would increase the tendency to oversteer. But this is an OEM part, Toyota would never make it stiff enough to make the car tail happy, you don't have to worry about that. I would imagine the front bar is already stiff enough for Toyota, they just soften up the rear bar on the regular model to make it more comfy for the grandpa sitting in the back. That is why they only put a bigger rear bar on the sport suspension. If you want a bigger front bar, buy it from TRD Japan.
www.lexuspartsworld.com
$87.39 for the bar, and you need 2 bigger bushings at $11.14 each.
I'll measure the size differences of the 2 bars and take some pics
#94
I just did some aggressive driving in my LS430 to see how the car feel with the stock sway bar before I put the bigger rear bar on, since I never really drive my LS430 aggressively. Boy I tell you it is nauseating to drive this big old boat aggressively thru turns, so the stock front sway bar is really stiff enough, because noone in their right mind would want to drive this car like a sports car. I do feel the rear can use a bit more roll stiffness because it does lean more, so maybe the OEM bigger rear bar is just enough. I'll let you guys know next week.
#95
#97
Just came back from the test drive after finished installing the bigger rear sway bar, as expected, there is a little less body roll in the back, the car feel more nimble and more fun to drive. I didn't bother taking a comparison picture as the 2 bars looks identical, you can't see 1mm diameter differences But it does take away some body roll though. Definitely a nice cheap upgrade for anyone who is bore. $110 total, takes 20 minutes to install
Now I want the TRD Sportivo sway bars!
#98
Thanks for being the pioneer! This will definitely be on the shopping list
However, isn't the TRD like $1k though???
#99
Definitely the cheapest upgrade one can do to a LS430, I mean that coin tray is $200!
You are welcome, glad I can share.
Yeah by the time the TRD kit get to California, it would be about $1000, but I plan to keep this car for at least 10 years, if not 20 years, so it would be worth it. I still have to measure the stock front bar diameter, but the TRD rear bar is only 1mm bigger then the OEM sport bar, we'll see, I might or might not get the TRD, but I always enjoy less body roll.
#100
If daizen would come out with control arm bushings, I would definitely do that when the LS hits 100k miles.
I did that for the GS + teins CS + 18's= firm, smooth and controlled. Not bone jarring at all.
#101
The only thing left is I can use a little less body roll, which the TRD bars would do.
#102
New member with 2005 ultra
Hello everyone. I am a new member. I just bought a 2005 ultra model. Our old 1996 ls was totaled. It had 250k. I find that the new one does not handle rough roads as well. The old one wasuch smoother over the bumps. I have the air suspension with 93k miles. The warranty is good until 100k. The dealer says that nothing is wrong with the suspension. He said there was no fluid leaking and the computer is good. Does the air strut use hydrolic fluid?
Thanks for the help. Should I just replace it to the steel suspension? Where is the best place to buy the parts from and so you guys recommend any mechanic in the Chicago area? Thanks a lot.
#103
Wiggle in rear
I forgot to mention that I get a wiggle dealing in the rear over hard bumps. It just does not soak up the big bumps like the 96 did. I tried pressing down on ech corner of the car but all four sides seem pretty stiff. Also the high setting does not do anything to the hight of the car. Thanks guys.
#104
Pictures
Does anyone have any pictures of the full install? Also, are you limited to only lexus parts? Can you buy aftermarket parts? If so, does anyone have an aftermarket parts list? Can I just look for parts for a ls430 (2004) sport?
If you can and no one has a list I can try to make one. I'm just posting here before I start doing all of the research.
ANY help is greatly appreciated! I've got to replace my rear air shocks as soon as possible (before I blow out two more tires).
Thanks!
Thanks!
#105
How much stiffer is the stock(nonsport) suspension over the UL's air suspension?
My RR strut got bad after my dealer replaced the RR hub bearing. Very strange though. Thx
