UL stock air suspension to steel springs conversion infos
Old 03-26-09, 02:36 PM
BNR34
BNR34's Avatar
Originally Posted by junjdm
nice...this is good to know for the future...I hate the hazard light on the dash, esp if you know nothings wrong w/ it....
Definitely. It was such a relieve for me when no light comes on the dash!
Old 03-27-09, 10:43 AM
BNR34
BNR34's Avatar
Everything is ordered and everything is in stock in Los Angeles! So I should have all the parts in a few days
I love owning a Japanese car in Southern California, everything is in stock in LA!!
Old 03-27-09, 03:41 PM
jman-LS430
jman-LS430's Avatar
Originally Posted by BNR34
Then I can go start a false rumor that Lexus does indeed offered the UL package with the factory sport suspension without the costly air suspension. They are REALLY rare, but they are out there, you just have to find them
LOL, I'd actually seriously put the "Sport" decal on the side just because it is a conversion that you will have done on a UL.
Good luck on this Jeff, sounds like you are underway.
Old 03-29-09, 01:37 AM
AlpineGt66
AlpineGt66's Avatar
can you please post the parts and part #'s. Are you converting everything with oem stuff or will you be using aftermarket springs/shocks? Just to ask a newbie question on this topic? What all has to be converted on an UL to make the spring/shock combo work? Also on the regular LS, and sport LS, are just the shocks diff? Or is it both the shock and spring? Thanks A lot
stuckincal (02-07-20)
Old 03-29-09, 06:11 AM
BNR34
BNR34's Avatar
I am undecided, I usually don't like to add any sticker/emblem to my cars, but I don't mind having an OEM emblem on the car that I actually have the equipment of. I'll see how I feel once I get everything done.
Thanks J. Let's get together once I get everything done to show off my car to you I'll bring the buffer to address any concerns you have on your black paint
Old 03-29-09, 06:22 AM
BNR34
BNR34's Avatar
I will post the complete list once I get everything, I don't have all the part #s right now.
I am using OEM sport shocks and aftermarket Tanabe NF210 lowering springs.
Nothing needs to be done really, all mechanical parts are interchangable, everything bolt up to the same location using the same hardwares. The biggest question to me before was how to disable the air suspension computer to avoid an error message showing up on the dash. The answer is, just pull the fuse on the air compressor to disable that, and no warning message is a result of that.
The OEM sport suspension consist of:
Firmer shocks
Stiffer springs
Bigger rear sway bars with bigger bushings
Firmer bushings on the upper A-arms front and rear
zeek (08-01-18)
Old 03-30-09, 05:20 PM
jman-LS430
jman-LS430's Avatar
Can't wait to see your car when you are done. Looking forward to it.
Old 03-31-09, 07:50 AM
BNR34
BNR34's Avatar
Thanks J
Old 03-31-09, 10:56 AM
juniorEXE
juniorEXE's Avatar
good luck!
Old 03-31-09, 11:00 AM
BNR34
BNR34's Avatar
Originally Posted by juniorEXE
good luck!
Thanks. Everything is figured out, I just have to get it done
Old 04-09-09, 11:04 PM
BNR34
BNR34's Avatar
I got all the parts in, here are all the Lexus part's # you need to do the conversion:
Front:
Sport shock: 48510-80131
Strut top (comes with rubber insulator and bump stop): 48680-50110
Big top washer: 48680-22050
Rear:
Sport shock: 48530-80141
rubber insulator for the spring: 48258-50020
Big rubber insulator: 48257-50020
Bump stop: 48341-50070
Strut top: 48755-50100
Big top washer: 48755-50110
I got the Tanabe NF210 lowering springs, Tanabe part # TNF088
The following 2 users liked this post by BNR34:
314 (01-09-21), stuckincal (02-07-20)
Old 04-10-09, 12:01 AM
blacksc400
Car Chat Moderator
blacksc400's Avatar
Cool, so what's the total cost of them?
Old 04-10-09, 09:17 AM
BNR34
BNR34's Avatar
Total shipped to my door:
All Lexus parts: $1330
NF210: $215
So doing the conversion on the entire car is cheaper then replacing one air strut at the dealer
Old 04-10-09, 09:31 AM
sojah
sojah's Avatar
wow, nice to know, specially since i have the UL n all... thanks for the info.
Old 04-11-09, 06:51 PM
I6turbo
I6turbo's Avatar
The issue I am facing now, is how to remove the C-pillars interior panel, they are mounted so well, it is hard to pull off, and I don't want to break anything. You have to remove these panels and the rear shelf in order to get to the strut top's nuts. I am gonna seek professional help on how to remove the panels.
FYI, you do not have to remove the rear shelf, assuming the air shocks mount the same way as the standard shocks. Just pop out the 2 little plastic rivet thingees near the center of the rear shelf and lift the front of the shelf enough that you can get your hands in there. I propped mine up with a large diameter flashlight laying on its side, which doubled as a light source to see wtf I was doing in there.
Quick Reply: UL stock air suspension to steel springs conversion infos
