04-06 stock 5-spoke wheels and spacers
now that everyone is on this subject just wondering i have read other trends where they say spacer put to much stress on the car ball joint ..bolts and etc.. and kinda messes with the alignment is this true......
and also is it bad to purchase a universal spacer from a locale rim shop like the ones they sell on ebay?????
Stresses
With everything said, I'm sure Lexus has made a far superior ball joint to withstand any failures. Also, any premature failures will probably not occur well into the 150K range, or longer.
It does in away. I had spacers on my other LS and did have to get my car re-aligned quite often.
avoid all problems and get the spacers that have their own studs. You bolt the spacer to the studs on the hub and then bolt the wheel to the studs on the spacers. Project Kics or H&R are a couple of good brands to look at.
the smallest spacer available with its own studs are 20mm.from what i'ved seen.using spacers will put some stress on your wheel bearings and make them wear out faster.using low offset wheels will do that too.
BahHumBug
ichiba sells bolt-on adapters that range from 15-25mm.
http://www.ichiba-usa.com/lslsls.html
plus you won't need centering rings, these are hubcentric to toylex cars at 60.1mm centerbore.
only catch is that the OEM wheels have to have spaces in them for the oe-studs to protrude
(look like this:
they can NOT be solid.)
if they are solid then you can't really use any adapters, you'll have to to get something like Ichiba's V1 spacer and some extended studs to press into your hub, more work but you wouldn't really have a choice.
(look like this:
(look like this:
(look like this:
