Speaker Issue
Old 10-13-08, 04:41 PM
JemmyTran
JemmyTran's Avatar
Default Speaker Issue
I have this issue a while back and just now had the time to check it out. I removed all the door panels to silicone the speakers and my rear driver side speaker does not work. I switch the two rear speakers to test it and works fine. Does anyone know how do i get this to work? if it is not the speaker then what is it?
Old 10-14-08, 12:57 PM
yuri.ber
yuri.ber's Avatar
Try to check the cable that goes to the speaker. When I removed the rear deck to silicone glue my sub I discovered that the sub is not ripped but it wasn't working, so I took it out and checked it with tester and it was dead.
But if you're saying that you checked the speaker, that could be cables.
Old 10-14-08, 06:10 PM
JemmyTran
JemmyTran's Avatar
if it is the cables then what can I do? I would have to check the wires from beginning to end and i dont know where to start
Old 10-14-08, 08:17 PM
yuri.ber
yuri.ber's Avatar
First start with checking the connection junction of cables. Then go down the cable as far as you can. I think though that the problem is at cable junction.
Old 10-16-08, 05:48 PM
JemmyTran
JemmyTran's Avatar
thanks alot man I will do that
Old 10-17-08, 09:33 AM
yuri.ber
yuri.ber's Avatar
You are very welcome
Mrjbeck112
09-19-17 11:29 PM
SlickRSM
05-09-12 06:26 AM
sigers98
02-22-08 11:09 PM
qpdo
11-11-07 08:40 PM
RSX989
03-12-06 11:11 AM
Quick Reply: Speaker Issue
