Offset question: BBS LMs
Old 09-29-08, 08:06 PM
el2ok
el2ok's Avatar
Default Offset question: BBS LMs
I'm thinking about picking up a set of LMs, but I'm not too sure about the offsets.
20x8.5 +36 F, 20x10.5 +38 R
Tires:Falken 452s 245/35/20 F and 275/30/20 rear
Would I have to roll/shave my fenders?
Old 09-29-08, 08:59 PM
SH212
Dances with goats
SH212's Avatar
when you get them take pics lol
Old 09-29-08, 09:23 PM
el2ok
el2ok's Avatar
Anyone know the specs on these LMs?
Old 09-29-08, 10:52 PM
BIGGZ
BIGGZ's Avatar
With those specs,I'm pretty sure the rear fenders gonna need to be rolled.and the fronts shouldn't have any problems clearing.
Old 10-01-08, 10:28 PM
solo
solo's Avatar
didnt know BMW shared the same 5x114 bolt pattern.
post pics!
Old 10-01-08, 11:02 PM
el2ok
el2ok's Avatar
post pics!
The original bolt patern is 5x114, but the previous owner used adapters to put them on his M5
Old 10-01-08, 11:17 PM
solo
solo's Avatar
then you are old lucky **** to rock one of the most respected wheel of all time. congrats. let me know if you ever want to let them go.
Old 10-01-08, 11:27 PM
el2ok
el2ok's Avatar
This will be my second set of LMs. I have a set on my M3 too.
Crap, the wheels may be 5x112. I havn't tried to fit them yet. Anyone know if it would be possible to change the bolt patter to 5x114?
Old 10-02-08, 11:12 AM
teamplayer
teamplayer's Avatar
With that wheel and tire size and offset, you may have some rubbing issues when turning, depending on how low you are.
On my 04, I had 20 x 8.5 (+40) on the front with a 235/35-20. When I make a sharp turn going up a semi-steep driveway, I'd rub the crap out of my fender (on the front). Now my right side fender has is slightly pulled out from my rubbing tire.
Old 10-02-08, 11:21 AM
solo
solo's Avatar
20x9.5 & 20x10.5 with 35mm is safe.
just shave off the inner fender lip..
and dun forget to run stretches. =)
13FSPORT
GS F (2016-present)
04-10-17 03:35 PM
Max16
IS F (2008-2014)
11-24-16 08:06 AM
Lexura1414
IS F (2008-2014)
06-26-12 11:22 AM
bg_281
07-17-09 02:02 PM
Felix gs43
05-03-07 06:17 PM
Quick Reply: Offset question: BBS LMs
