Side Mirrors LED Light Install w/ Pix
#46
Cliff Notes:
Feel free to correct if I'm off.
Mirror: WLED-WHP
Door: WLED-WHP
Trunk: WLED-WHP
Reverse: 194 (wedge)
License Plate: WLED-X6
Interior: ??
Footwell: ??
Door latch (interior):??
Mirror: WLED-WHP
Door: WLED-WHP
Trunk: WLED-WHP
Interior: ??
Footwell: ??
#47
Mirror: WLED-WHP
Door: WLED-WHP
Trunk: WLED-WHP
Map Lights & Rear Map Lights: BA9 LED's
Dome:31mm festoon
I have no idea what the door handle and foot lights are, they are do dayum small it looks like a real PITA to swap them out.
Door: WLED-WHP
Trunk: WLED-WHP
Dome:31mm festoon
#49
Mirror: WLED-WHP
Door: WLED-WHP
Trunk: WLED-WHP
Dome:31mm festoon
Door: WLED-WHP
Trunk: WLED-WHP
Dome:31mm festoon
#50
Mirror: 194(wedge bulb)
Door: 194(wedge bulb)
Trunk: 194(wedge bulb)
License Plate: 194(wedge bulb)
Dome:3022 festoon bulb
#55
#56
Sojah,
No problem the same with me! (was to scared to try those steps) but i called the dealer they said it pops right out i said are u sure??response (yes).... then i asked can they do it for me they said we charge by the hour and it only take five mins to do ....when i looked at this forum i said no way in hell that's going told take five mins... dealer to me to use a flat screw-driver..but i tried a old credit card to be safe ....take your time don't rush!!!!!!!!!!!!!!!!!!
#57
Okay Swagga82,
That is very cool news, now can you share more info like//
What was the best angle with the crediit card/flat head?
Where they easy to pop back in or you had to work to pop them back in?
I did mine already from the write up but it would help others who have not tried it yet.
#58
well i should of took more PIX, my fault but i used the edge of the credit card and popped it out from each side.. i had to used the same credit card to pop it right back in that's why i say try not to RUSH and take your time....!!!! SORRY for THE lack of pix i was kinda hype when the dealer told me it pops right out i just ran outside and started working!!!
#59
hmmm,, yeah, so my passenger side light did not pop out like your pic at all. the whole freakin plastic cover broke off somewhat cleanly but popped out. i changed the light and was really stressing cuz it wouldn't really stay flush when i popped it back in. it kinda was loose and i was worried about it falling off if i hit a bump while driving. so i had to super glue it back on... another one of my favorite things to do on a lexus (first time so far on the ls 430). the other one popped out cleanly like your pic but was a ***** to get out and even harder to get back in. i guess all is good and it seems okay unless you run your fingers along the ridges of the clear plastic part under the mirror then you will feel some rough raised spots.
like the guy swagga said if you are going to do this somewhat 'hack' method do it very slowly so as not to mess it up like i did. i wonder if this is just a prelude to me installing the datasystems air controller thing once the package arrives...?? sure hope not...
#60
