Datasystem Controller Writeup with Pix
Old 03-24-08, 12:57 PM
racinstyle
racinstyle's Avatar
excellent write up. Ill get back to you on your question on to why it wont go into superlow. I think its in safety mod, lemme look up how to get it back into reg mode so you can dump to superlow.
Old 03-24-08, 02:32 PM
airtime
airtime's Avatar
Thanks, but I got it to work. Just had to keep my finger on the lower right hand button when turning on the ignition. Then I can select the superlow mode. Just dumped my car and damn, don't think I can get a jack under the car if the compressor fails
Old 03-24-08, 02:36 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
oh, lower right button? so it's different from the ls460l then huh?
well at least i hope my pm helped
Old 03-24-08, 03:27 PM
GS3Tek
Forum Moderator
GS3Tek's Avatar
Thumbs up
Awesome writeup airtime
Most of the time, these DIY writeup is harder and more time consuming than the
actual installation itself
"Bookmarked!!!"
Old 03-24-08, 03:52 PM
airtime
airtime's Avatar
In all, it took about 40 minutes from start to finish. Didn't really rush it as I was in no hurry. If I had to do it again, I'd say it'll take 20 minutes or so.
Old 03-24-08, 05:27 PM
racinstyle
racinstyle's Avatar
you cant drive on L
Old 03-24-08, 05:47 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
you cant drive on L
that's coz' the speed sensor is plugged in right? is that the plug behind the glove box? on the ls460l, the speed sensors are behind the nav, i didn't connect it and it retains full functionality and i can drive in L if i want (and did)
Old 03-24-08, 07:03 PM
racinstyle
racinstyle's Avatar
orly? wish i would have known that when I had my datasystem controller
Old 03-24-08, 07:13 PM
airtime
airtime's Avatar
I should try and disconnect the lead to the other side. I have already via the controller, turned off the speed function. If this works, it could save some installation time for those new installer.
Oh, no way I can drive in "L" or "9" tried to move the car and the front wheels scraped a bit. "8" was pretty tight but doable. "7" and lower is where its at.
Old 03-24-08, 08:05 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Great write up, thanks for the tutorial, sure will come in handy. I posted i in the FAQ section for now.
Fsport4lif (03-06-23)
Old 03-25-08, 09:18 AM
BNR34
BNR34's Avatar
Is this lead the one wire you had to extend yourself? And where does it plugs in, behind the glove box or under the steering wheel?
Old 03-25-08, 09:41 AM
airtime
airtime's Avatar
Yes, this is the extended lead (single wire). It is the blue plug that goes behind the glove box, speed sensor wiring I believe. Under the steering wheel is the active suspension module that has 3 plugs.
Old 03-25-08, 10:53 AM
BNR34
BNR34's Avatar
Thank you
I am sure you tried pressing the lower left hand button to see if you can access the TEMS menu? No luck?
Old 03-25-08, 11:43 AM
airtime
airtime's Avatar
Still waiting for my buddy to translate the TEMS page to see what I'm doing wrong or not doing.
Old 03-25-08, 11:44 AM
BNR34
BNR34's Avatar
Cool, thanks
Quick Reply: Datasystem Controller Writeup with Pix
