Where to find Data Air Suspension Controller?
Old 07-10-09, 08:33 PM
  #46
jocko
jocko's Avatar
Originally Posted by LSin75075
I tried this on my 01 UL and after I lowered all 4 sensor arms as low as they'd go, my car would stay in HIGH suspension mode, even if you set the switch to normal, and then my warning light came on for headlamp leveling error?!?!? I tried setting them to halfway between normal and low and same thing.
did u find a fix or not?
Old 01-14-10, 02:06 PM
  #47
juhaims
juhaims's Avatar
what would happen if I dont use the rod anymore?
Old 01-14-10, 03:12 PM
  #48
sojah
sojah's Avatar
just my guesss: very bad things
Old 09-14-10, 06:49 AM
  #49
dbltakegs3
dbltakegs3's Avatar
Default Links
For some reason after i adjusted the links i cant get the car to even out. driver side is about 2 finger gaps and pass side is about 1 finger gap. I tried to raise the passanger side up, I adjusted it all the way up but it doesnt seem to be raising.
Any tips and tricks you guys can give me?
Old 05-05-12, 03:44 PM
  #50
DjMidas
DjMidas's Avatar
Originally Posted by GS3Tek
Bumping frenzy tonight!!! Good diy write up airtime
Will this work for a 2002 LS430 UL?
Old 05-06-12, 11:53 AM
  #51
ultm8mind
ultm8mind's Avatar
yes the ASC680 will work for the 01-06, just uses different harnesses for 01-03 and 04-06
Old 03-26-14, 05:48 PM
  #52
UGKkllr
UGKkllr's Avatar
Gonna bring back another old thread instead of making a new one. So what is the difference between the 663 and the 680 ? The 680 has "Speed Sensitive Automatic Height Control" is that the only difference ? I have a 2001 UL LS430 , and the 663 will work for me but if the 680 is that much better and it works for the 2001 then I am interested in knowing why. If i use it just to go down a few inches and get rid of most of the gap when I run 20's , will it be easier on the stock suspension ? Or is it hard on the factory bags no matter what setting I ride around on ? I am not interested in ever going low enough for the tires to be tucked
Old 03-26-14, 05:54 PM
  #53
ultm8mind
ultm8mind's Avatar
I don't think it's much harder on your factory bags, but with the DataSystems Controller it does go up and down slower than aftermarket. I know the 680 has the lead that connects to the speed height under the glovebox in the 04-06, most people go without hooking it up though from what I've noticed. I didn't hook mine up when I installed my 680, which I am selling now. Hope this helps.
Old 03-26-14, 06:54 PM
  #54
UGKkllr
UGKkllr's Avatar
Thanks for the reply . I am basically looking to drop a few inches and leave it be for the most part. Maybe once in a blue moon at a meet or a show , I might put it all the way down.
Old 04-23-14, 10:16 PM
  #55
deejayrock
deejayrock's Avatar
Anyone looking to purchase a data controller 680, i should be selling mine shortly with a harness for an 04-06 LS. Only selling because Im going full aftermarket air, thanks
Old 04-24-14, 09:49 AM
  #56
UCF30_SD
UCF30_SD's Avatar
Deejayrock, I pm'd you
Old 04-24-14, 10:41 AM
  #57
VerbalKent
VerbalKent's Avatar
PM'd you as well DeeJay...
Old 04-25-14, 08:30 AM
  #58
deejayrock
deejayrock's Avatar
thanks guys, responded back
Ingelsgard
01-17-18 07:06 PM
Black31385
12-09-14 08:53 PM
GSTEMP
VIP Style
14
01-08-10 11:40 PM
4play4dr
Suspension and Brakes
03-12-08 01:33 AM
PK_Celsior
VIP Style
01-13-08 01:13 AM
Quick Reply: Where to find Data Air Suspension Controller?
