Dealer wants to over-inflate my tires!?
Old 11-09-07, 03:13 AM
drink300
drink300's Avatar
Angry Dealer wants to over-inflate my tires!?
I have a 2004 LS430. My low tire warning light has been coming on. I know this is an issue with the 2004 models. What is the REAL fix for this issue?
My dealer is telling me that my BRAND NEW tires are underinflated for the altitude we are at 5,500ft above sea level. They want to fix the low tire light problem by overinflating the tires by 4PSI. I am NOT happy about this situation and would like insight from anyone here who knows about this stuff.
Thanks!!
Old 11-09-07, 05:47 AM
Nelson
Nelson's Avatar
Thanks!!
There is no actual pressure sensor on the 2004 model. It works by sensing the change in sound frequency at the wheel which is an indication that something has changed and thus the pressure must be low.
The reset button (actually two buttons) is not easy to reach. It is far under the dash near your right knee. I believe the button for tire presure reset is the one that is closer to you. In the manual there is information on the reset procedure which involves going on a long freeway drive after pushing the reset button. That procedure seemed to be unrealistic for me.
The reset button is not always the total solution to making the warning go away. Sometimes after a lot of freeway driving (a few days or weeks) the warning will come back. This happened to me when I got new tires. I had the dealer do the reset with their computer and that solved the problem. It was during that series of events that I confirmed the information I'm posting here. The write up person was not sure and had to check to find the answer (he initially thought there were actual pressure sensors...as many people do).
By the way...the search function is your friend.
Old 11-09-07, 08:34 AM
airtime
airtime's Avatar
Under dash, button to the right is the Tire Set.
Old 11-09-07, 09:59 AM
ayonnebay
ayonnebay's Avatar
Originally Posted by Nelson
The reset button ......
As I recall, if the problem keeps repeating, it's more than just pressing the "Reset" button. The system has to be re-initialized - by holding the button for a few minutes, or something like that - and I believe an "INITIALIZED" message
comes up on the display.
I had the problem once and somehow found the answer somewhere at that time. I'll try to find the actual procedure .....
Old 11-09-07, 10:10 AM
ayonnebay
ayonnebay's Avatar
Yeah, I found it - It's in the Owners Manual (2004LS, Pg 98):
"After replacing tires or wheels, adjust all 4 tires to specified pressure and initialize the tire pressure warning system. To initialize the system, turn the ignition switch to "ON" and push the tire pressure warning system reset switch for longer than 3 seconds with the vehicle stopped. The following message appears
" ! Pressure Initial "
Don't just do a quick press of the button to get rid of the warning, in other words. The system must be initialized.
Old 11-09-07, 01:51 PM
drink300
drink300's Avatar
Post
Thank you all for the quick responses. I appreciate it.
I'll try the reset button fixes here.
However, does anyone know if the tire pressure realy does need to be higher here at high altitude? Or is this just dealer BS?
malso70
01-19-19 12:42 PM
dlap
03-07-10 06:24 AM
rsg
08-02-08 11:45 AM
freshwater
GX - 1st Gen (2004-2009)
11-10-07 08:09 AM
Kyosuke86
01-07-06 03:37 AM
Quick Reply: Dealer wants to over-inflate my tires!?
