Replace Door lock Actuator
Old 08-08-07, 07:41 PM
tham430
tham430's Avatar
Default Replace Door lock Actuator
Hey, does anyone have directions, pictures etc on how to get the drivers door panel off? I need to change a power lock actuator. Any help is appreciated.
TIM
Old 08-09-07, 09:01 AM
badbronco8
badbronco8's Avatar
All I have to say is "Get Ready". Mine just broke and it was 700 dollars to fix and 564 of those dollars was the actual part, with a 20% Lexus discount. It sucks. I almost got rid of the car with the fear of 1,000 dollar a piece shocks and 700 dollar door locks. It was recommended not to do the job myself due to the complexity of removing the actuator. Be careful that you don't take half the door apart and figure out that it is not a DIY job.
My .02
Ed
Old 08-11-07, 05:41 PM
tham430
tham430's Avatar
Wow, I wishI would've known. You can buy that part for about $180.00 from irontoad.com. I'm pretty mechanically inclined, used to work on airplanes so I think I'll be okay doing it myself. I just need to know where the bolts and fastners are so I don't mess up the door panel. I guess I'll just have too buy the manuals. Thanks.
TIM
Old 08-13-07, 06:31 PM
VQT
VQT's Avatar
TIM
The service manual isn't cheap either.
Old 08-13-07, 06:58 PM
ancdmd
ancdmd's Avatar
I need to fix my door speaker so anyone who can give advice on removing the door panel please chime in.
Old 08-13-07, 07:34 PM
IronCobra
IronCobra's Avatar
Irontoad.com is friggin awesome! Ryan is a huge help!
Old 08-13-07, 08:20 PM
badbronco8
badbronco8's Avatar
I doubt that the 180.00 actuator is the one my car requires. I have the ULTRA with the easy closer doors. That makes it the actuator over 2x as expensive. Look it up. The regular ls430 door lock is 280 from dealer so I beleive that is the part you are referring to as costing 180 dollars. I did exteeensive research before I let the mechanic touch this.
Old 09-12-07, 01:55 PM
tham430
tham430's Avatar
Thanks for the info. I have a ul as well with the closers, so I'll do some additional checking, but when I provided the info to it he knew it was a ul so we'll see. Thanks again.
TIM
Old 09-13-07, 09:50 PM
VQT
VQT's Avatar
Have you bought the manual yet? LS430 have total of three volumes
Old 11-15-07, 09:01 PM
tham430
tham430's Avatar
No I haven't purchased the manual as of yet but I did price them. They were $150 each, and it is two of them.
Old 11-15-07, 09:04 PM
VQT
VQT's Avatar
Actually it is three volumes and I just got them. You need to buy the manual so it will be a lot easier to fixed things for the Lexus...
Old 07-19-13, 11:54 PM
harryford
harryford's Avatar
Not to resurrect an old thread, but in case anyone is searching; my door locking actuator broke and it was replaced with a 10$ aftermarket one that was spliced in. Is it perfect? No. Does it may more noise? Yes. Was it a PITA to get to work correctly? Yes. After looking on rockauto and seeing they go for 500$, trust me get a simple door locking actuator off amazon.
Old 07-20-13, 10:01 AM
beneteau
beneteau's Avatar
DIY---Door Lock Actuator Tutorial LS 430
http://www.shastaanesthesia.com/Lexu.../actuator.html
rhwimmers
06-28-12 08:32 AM
napa2u
08-08-11 09:08 PM
corkycal
10-29-10 02:20 PM
Bri-Guy
05-17-08 07:45 PM
Quick Reply: Replace Door lock Actuator
