DIY - Updating your Navigation DVD with new version
Old 10-09-10, 10:58 AM
  #46
MGa
MGa's Avatar
Originally Posted by Carnut
My own personal knowledge is limited, so I would have to say, "Go to an authorized Lexus Dealership and get them to assist you in any way they can.
Their answer is buy an European model or they want to change the whole system which costs almoust half the price of the car.
Old 09-05-16, 02:16 PM
  #47
jcvilla28
jcvilla28's Avatar
I there, so I am a little confused, I own an 2001 LS 430 so can I upgrade to version 10.1 ?? or that version are only for newer models
Thanks
Old 09-05-16, 02:30 PM
  #48
hyperopt
hyperopt's Avatar
You can update to any version as long it is for your particular gen (2/3) and region.
Old 09-06-16, 03:51 PM
  #49
Brandicus
Brandicus's Avatar
Thanks
I just did the upgrade on my 03. Im sure the "latest" and last upgrade you can do is to 13.1, which was released in 2013. It will be the final release from what im told, but was a MAJOR improvement over my stock 2003 map haha.
Also just for reference I got a burned dvd off craigslist for $20, pretty good deal and easy to justify.
Old 09-07-16, 06:30 AM
  #50
Damian@FI
Damian@FI's Avatar
Originally Posted by navguy2011
I have version 10.1 DVDs available for all gens. PM if interested.
Australian maps by any chance?
Old 09-07-16, 11:23 AM
  #51
tradosauru
tradosauru's Avatar
10 years later and DVD's are obsolete. I'm still wondering why new cars include DVD players?
Old 09-07-16, 09:45 PM
  #52
n4osg
n4osg's Avatar
So it seems it is possible to upgrade to a different dvd drive unit and purchase the disc. My example : I have a 2001 LS430 with apparently gen 2 software. It gives
the "disc not found" error. It worked a few months back but has finally stopped, cleaning disc, resetting, nothing works..So if I buy a gen 4 drive unit- for example
the 86841-50090 and plug it in-put the correct dvd disc, will it work ?? Im not concerned about voice - only that the dvd gps map will work. I just want to get rid of the
error message so I can run diagnostics on the radio -tuner-amp components. Thanks for any ideas.
Old 09-08-16, 08:56 AM
  #53
Daspyda
Daspyda's Avatar
Here's a template of what to order:
Old 09-08-16, 10:09 AM
  #54
Tom57
Tom57's Avatar
Yes. See my posts on these threads with the info that you need >
https://www.clublexus.com/forums/ls-...-dvd-disk.html
https://www.clublexus.com/forums/ls-...v-upgrade.html
Old 09-08-16, 07:09 PM
  #55
n4osg
n4osg's Avatar
Thanks for the advice. Im looking for the 86841-50090 now. Good write-up
Old 09-10-16, 09:18 PM
  #56
jamsvet
jamsvet's Avatar
BTW If you notice where these items are located, you will realize that it is not a good idea to carry 2 1/2 gallons of water in the trunk right above these pricey little items. You can ask me how I know these things.
Old 09-10-16, 10:28 PM
  #57
aypues
aypues's Avatar
2016 discs will be coming out shortly. Prob within a few weeks.
Old 09-11-16, 10:08 AM
  #58
Tom57
Tom57's Avatar
Yes, they're located in a vulnerable spot ... if a cooler tips over. Design should've included either a warning or a vapor/water barrier over those components.
Old 09-11-16, 10:31 AM
  #59
n4osg
n4osg's Avatar
Not only do they get dirty with dust but they are a pain to remove. I just replaced the tuner which sits next to the nav unit and it wasnt easy removing the
side black trunk cover. Concerning the navigation box: does anyone know what the extra connectors are used for on the 86841-50090 unit- my 01 nav
unit even has one connector not used and now I see the 03-05 units have added another connector on the rear.
Old 09-11-16, 11:30 AM
  #60
Tom57
Tom57's Avatar
Extra connector(s) were for the Lexus Link system (on the '01 - '03 model years) which was discontinued - there was a Lexus campaign for dealer-removal/disconnect. When that system is disconnected, there are two (2) wire harness connectors that are unused. (I wrapped mine in my '01 with waterproofing plastic to avoid any moisture-related issues.)
The extra connectors on the Nav DVD player are unused.
Quick Reply: DIY - Updating your Navigation DVD with new version
