Question: A Simple Cell Phone 12V Adapter Mod -- Maybe?
THE QUESTION:
Does anyone out there know how to easily (and safely, i.e., without damaging anything) remove the ashtray/lighter compartment (see photo, pointer #1), or if that's not possible to separate from the larger console panel (pointer #2), how to remove the whole panel?
IN CASE YOU'RE WONDERING WHY I ASK, READ ON!:
I would like to take further advantage of the fact that my Bluetooth-enabled T-Mobile MDA handheld device happens to fit snugly and perfectly into the ashtray/lighter compartment of my '04 LS430 center console, and also keep the MDA powered-up while driving using its 12V auto-adapter. But I really don't want to just plug the unsightly and bulky adapter directly into that outlet; I'd like to basically mod the adapter plug for the MDA to the underside of the ashtray/lighter compartment (i.e., electrically connecting the terminals of the adapter directly to the back-wiring of the 12V socket), such that the adapter is out-of-sight under the console, and then just pull a small portion of the cable & mini-USB tip through the small light hole already in the ashtray section. Hopefully you can "see" what I'm trying to explain!
If I can succeed in getting the panel (or ashtray section) apart, the rest should be very easy. I'd be happy to post photos as a sort-of "mod how-to" later.... And of course, it will be added to my humble list of Mods at the bottom of my sig!
Thanks-in-advance!
Thanks-in-advance!
3UZ-FEEEE
I don’t know, but I have the ashtray, and want to trade it for a storage compartment... if anyone smokers out there want to trade. Let me know.
EDIT: To remove that wooden panel, you insert a screw driver's tip (after covering it with tape so it wouldnt scratch anythign) then pull torwards you from where the cup holders are located. Thats how my 98 was. I have a strong feeling that the '04 is the same way. Just have to be careful when removing the wood, so nothing breaks.
RE: Question: A Simple Cell Phone 12V Adapter Mod -- Maybe?
...To remove that wooden panel, you insert a screw driver's tip (after covering it with tape so it wouldnt scratch anythign) then pull torwards you from where the cup holders are located. Thats how my 98 was. I have a strong feeling that the '04 is the same way. Just have to be careful when removing the wood, so nothing breaks.
Can anyone else with actual experience on an '04 (or other pre-'07) please confirm if this method is safe and effective? I'd like to try this on Monday with some degree of assurance that I won't break anything....
gsean400
10-20-14 05:20 AM
bjp202
11-04-10 09:58 PM
