Hood shock/strut fix (The Mother thread)
Old 12-15-07, 07:10 PM
  #91
turbosix
turbosix's Avatar
Originally Posted by PK_Celsior
i use that ebay stuff. works purdie good until your hood knock you out haha. i notice the hood strut on ebay are like stupid industrial. thats why it leaves a lil dent into your hood. but o wellps haha i cant afford to pay 80 bucks a strut for my hood so thats 160 bucks to cover both sides of your hood and maybe another 120 for an hour of labor. can always buy the part yourself and do it yourself only takes a few minutes. just make sure you got someone to hold up the hood fo ya . its prettyy darn heavy
i use an adjustable shower curtain rod... haha... collapses to about 2.5ft long and wil adjust long enough to hold my hood up when i need it
Old 12-16-07, 12:09 PM
  #92
damon
damon's Avatar
I have seen no evidence of hood bending with the 3 sets (family has 3 LS400's) I just put on from the link above.
damon
Old 12-16-07, 12:33 PM
  #93
kwikrnu
kwikrnu's Avatar
damon
me either
Old 12-16-07, 03:54 PM
  #94
PK_Celsior
PK_Celsior's Avatar
hehe just depends on what kind of struts you have. i believe i have struts that arent meant for my hood. by lookin at the reaction when it pops up.
Old 06-08-08, 08:51 AM
  #95
RocKrawler
RocKrawler's Avatar
Need some help, been searching and cant find the answer (maybe using the wrong keywords): How do you get the old struts off? Do they stay attached to the factory pins and just unbolt them from the hood & fender? Is there a clip I'm missing that lets them release from the ball? Do you have to pry them a certain way? HELP!
Old 06-08-08, 02:22 PM
  #96
kwikrnu
kwikrnu's Avatar
There is a clip that needs to be removed before they can be taken off. I had to grind down the edge to get to the clip to remove mine. Then I bought some replacement struts off ebay which bent my hood. I then found factory replacements and did it right which is what I should have done from the start. The factory ones are cheap and come with struts already mounted on the hardware. You can see where to get them with a search.
Old 06-08-08, 06:01 PM
  #97
RocKrawler
RocKrawler's Avatar
I guess thats what I'm looking for, I cant seem to find a clip thats retaining it. Any detailed pics or crayon drawings on a used napkin?
Old 06-09-08, 07:16 PM
  #98
damon
damon's Avatar
What brand are the version that causes a bent hood?
Old 06-17-08, 05:13 PM
  #99
Shadeed
Shadeed's Avatar
This is the poor man's fix.
I drilled 1 hole in each strut and put a cotter pin through to hold up the hood- the pins are attached to the strut by a piece of wire (optional).
A broom works well to hold up the hood while you are working on the struts.
On drilling the strut you may see some oil leaking from the strut, but this stops after a while.
The hood becomes very heavy after you do this, so ladies, be forewarned.
Old 06-17-08, 06:41 PM
  #100
Shadeed
Shadeed's Avatar
Has anyone tried the STRONG ARM Lift supports from Advance auto parts?
I am wondering how well they fit and work.
They list for 21.88 each.
Old 06-17-08, 07:37 PM
  #101
UCF11
UCF11's Avatar
I always thought it was possible to get the orignals "recharged".
I will ask my father, he fixed the struts on his 1st gen with out replacing them with new ones.
Old 06-18-08, 08:52 PM
  #102
cjmeyer
cjmeyer's Avatar
I just unbolted mine.The new ones I purchased had new hardware and I just bolted it back up and was back in business
Old 07-13-08, 09:59 PM
  #103
ryanSC300lover
ryanSC300lover's Avatar
Anybody know where I can buy the hood struts (hood is falling down) for a 95 LS?
Old 07-13-08, 10:25 PM
  #104
PureDrifter
BahHumBug
PureDrifter's Avatar
ebay has them cheap
Old 07-14-08, 06:05 AM
  #105
dacecil
dacecil's Avatar
Advance Auto Parts or any major chain has them. Mine did not require and modification to install them and they work perfectly.
Quick Reply: Hood shock/strut fix (The Mother thread)
