Realistic EPA mileage ratings?
Old 02-19-17, 09:47 AM
YODAONE
YODAONE's Avatar
Default Realistic EPA mileage ratings?
Reviewing postings in various ClubLexus forums, the general consensus and physics suggests 100% gasoline provides better MPG over gasahol due to higher heat (BTU) content (same octane)
New car window stickers provide EPA mileage ratings .....
My question is whether auto manufacturers EPA compliance ratings reflect MPG using 100% gasoline or gasahol (10%)?
Anyone know definitively EPA guidelines with supporting documentation??
Thanks.
YODAONE is offline
Old 02-19-17, 12:26 PM
Banshee365
Banshee365's Avatar
I don't have proof but it's my understanding that test's are completed using ethanol-free fuel.
Banshee365 is offline
Old 02-19-17, 03:46 PM
YODAONE
YODAONE's Avatar
I agree but need something to corroborate... Most gasoline sold in US. is 10% ethanol yet our illustrious EPA allows straight gasoline for mileage ratings ??
YODAONE is offline
Old 02-19-17, 06:56 PM
Banshee365
Banshee365's Avatar
My guess is that they are allowed to get away with doing that and they take advantage of that as it may yield slightly better mpg numbers.
Could you imagine if manufacturers had to use E85 for their EPA testing? That would yield some atrocious numbers.
Old 02-19-17, 07:02 PM
brybo86
brybo86's Avatar
I have also read about automakers trucking in special 100% gas to run tests even when the testing facilities are in mandated e10 areas
brybo86 is offline
Old 02-19-17, 07:06 PM
RA40
Super Moderator
RA40's Avatar
Would you prefer this be moved to the Car Chat section?
RA40 is offline
Old 02-19-17, 09:17 PM
YODAONE
YODAONE's Avatar
Moving it to greater readership makes sense
YODAONE is offline
Old 02-21-17, 06:10 AM
GSteg
GSteg's Avatar
5. When I buy gas at the pump, it typically contains about 10% ethanol and other additives. Does EPA use a gasoline-ethanol blend for fuel economy testing?
No, EPA’s test fuel does not currently contain any ethanol or other oxygenates. However, EPA does account for the impact of low-level ethanol blends in our fuel economy estimates. Ethanol has a lower energy density than gasoline—about 1/3 less energy per gallon. That means a car operating on 10% ethanol would require about 3% more fuel to travel one mile than a car operating on gasoline and thus have about 3% lower fuel economy. EPA currently reduces all fuel economy test values by about 10% to account for ethanol in gasoline and other factors such as wind, hills, and road conditions. Later this decade, EPA is phasing in a requirement to change our federal emissions test fuel to include 10% ethanol by volume. Information about this change is available at: epa.gov/otaq/tier3.htm.
https://nepis.epa.gov/Exe/ZyPDF.cgi/...y=P100IENB.PDF
GSteg is offline
Old 02-21-17, 06:18 AM
mmarshall's Avatar
While it is true that ethanol has much less energy content than gasoline (requiring larger tanks for vehicles with high concentrations of ethanol to gasoline to attain the same cruising range), it really doesn't make much of a difference at the typical E10 (10% ethanol) concentrations sold at American pumps. By my math, it comes out to only about a 3% difference in overall mileage from pure gasoline. Now, for blends like the E85 (85% ethanol) that is produced in the Midwest (many GM and Chrysler engines can run on anything from 0 to E85)...that, of course, will be a different story.
mmarshall is offline
Old 02-21-17, 08:06 PM
Och
Och's Avatar
Most EPA mileage ratings are utter BS. It not uncommon to see real world mileage being half that of EPA claims.
Och is offline
Old 02-22-17, 07:00 AM
mmarshall's Avatar
If one drives sensibly on the Interstates, my real-world experience is that the Highway ratings are pretty accurate......even underestimated in some cases, as I sometimes do even better. However, in real-world stop-and-go driving, I agree......most of the City figures are overrated by about 2-3 MPG. And, keep in mind that, in general, all else equal, the lower the temperature, the lower the gas mileage. EPA tests are usually run at warmer temperatures.
Old 02-22-17, 08:18 AM
pbm317
pbm317's Avatar
While they're slow, they do make changes to their testing parameters and calculations. 2017 model year vehicles mark another change, which is why you may see 2017 ratings differ from 2016 model year, even with no change in the vehicle's specifications.
EPA is updating its method for calculating the fuel economy shown on new-car window stickers starting with the 2017 model year.
EPA periodically updates its methodology to account for changes in vehicle technologies, driver behavior, and/or driving conditions. The 2008 changes (see below) were broad revisions to the entire methodology that affected every vehicle.
The 2017 change updates some of the calculations used to estimate fuel economy. The new calculations are based on test data from model year 2011–2016 vehicles. So, they better reflect today's vehicle fleet of more fuel-efficient vehicles and advanced technologies such as hybrids and turbocharged engines.
Most vehicles are not affected by the new calculations. Some fuel economy estimates will decrease by 1 mpg, and a small number may be 2 mpg lower.
pbm317 is offline
Old 02-26-17, 08:55 PM
riredale
riredale's Avatar
I would also assume that the EPA tests are done with a fully-warm engine. With hybrids the numbers can be significantly lower.
My RX450h hybrid gets mileage in the high 20's--but only once the engine has warmed up. If, instead, my day consists of multiple 5-minute trips, the mileage average is more like 16mpg. The computer needs a warm engine before it can work its magic, and also the climate control system demands hot coolant for the heater in the winter. So the engine keeps running for the first 5 minutes whether the computer "needs" it for locomotion or not.
riredale is offline
dagsmcd
04-22-19 11:55 PM
maarp
06-27-18 01:18 PM
Jlacck
04-18-16 03:52 PM
Overclocker
04-11-07 03:14 PM
TonyES350
ES - 5th Gen (2007-2012)
07-10-06 03:41 AM
Quick Reply: Realistic EPA mileage ratings?
