Best way to get to driver blinker bulb change
Anyone can point me to the best and easiest way to change this driver side front side bulb (orange side marker), much appreciated
Don't forget to remove this one circled yellow in the link below first and then follow as is posted by fixmiester.
http://celsiorup.com/image/custom20/...Winker_026.jpg
UNCNOR (12-30-16)
I like to update this thread Incase someone down the road needs the bulb replace. The orange front blinker is held down by a screw, so do not pry it, it does not pop off you will end up breaking it. The best is to approach via the wheel liner, just a couple of screw and you can bent the wheel liner back and bent the front bumper back and just reach your arm in and twist off the bulb and replace with new bulb it's that easy. I repeat the lens does not come off, I'm not sure how member fixmeister was able to pop it off, since a screw is held in place and impossible to access unless you take out the whole front bumber
LexusFan2
ES - 5th Gen (2007-2012)
01-27-14 07:30 AM
