Top coolant hose end?
Old 12-24-16, 01:16 PM
wjlevan
wjlevan's Avatar
Default Top coolant hose end?
Hey guys, my 99 ls400 heater started blowing cold air. Turns out the coolant was pretty low.
I topped off the coolant, but noticed it started leaking under the car.
This hose isn't connected to anything and I spend 15 min under the hood and couldn't find the other end.
Where does this plug into??
Old 12-24-16, 02:38 PM
UNCNOR
UNCNOR's Avatar
Overflow hose.
Old 12-24-16, 03:12 PM
sha4000
sha4000's Avatar
That should be connected to a nipple on the passenger side of the radiator. That nipple is notorious for snapping off if you man handle the house while removing it.
Old 12-26-16, 08:08 AM
jaaa
jaaa's Avatar
No, UNCNOR is right, that's just the overflow hose that just hangs straight down. But you're right, that nipple on the radiator breaks quite easily if you lean on it.
Old 12-26-16, 05:31 PM
sha4000
sha4000's Avatar
My mistake your right I stand corrected.
Old 12-26-16, 06:25 PM
RA40
Super Moderator
RA40's Avatar
No worries with that, it doesn't attach to anything but is for overflow. The factory overflow hose has a bend that angles down along the reservoir. That one is fine, so long as any overflow is not directed at the alternator, ABS or into the serpentine belt to splatter coolant around the engine bay if venting out.
calteg
IS F (2008-2014)
02-11-16 09:35 AM
pman6
Maintenance
11-17-14 05:48 AM
2slixx
01-28-13 03:40 PM
Ren
GS - 1st Gen (1993-1997)
23
04-12-11 08:13 AM
TMaxxTim
Maintenance
11-17-04 01:32 AM
Quick Reply: Top coolant hose end?
