Vibration issue/low speed rumble SOLVED
It started with a whine at acceleration. Then the whine went away, but a strange vibrating rumble came in - usually when accelerating in second gear, so low speed. I was sure my AT was going to die. And I also started getting this high speed vibration at around 83mph which would go away around 86mph, and would come back around 93mph.
Then it hit me: it must be the center support bearing.
Replaced the center support bearing and the problems at low speed are gone! Whew, it was NOT my A/T.
Now, lets hope that high speed vibration is gone too. If not, I am thinking it must be differential bushings.
Both vibrations were mostly felt in my seat, not in the front, but from the middle/rear of the car...
So in case you have the same problem you know what to do!
oldskewel (01-21-19)
Just found this old post, want to add something for lurkers: if you want to replace center support bearing, do NOT use an aftermarket one. I decided to risk it and bought a new, cheap one from e-bay, for $55 and it is already making noises, only two years later. It is OK, but I can hear it whine from time to time, so the quality is in the crapper. Stay away from non-oem parts. I will replace this with OEM first chance I get.
spuds (10-27-18)
Thanks Peter.Posts like yours always make me feel better when buying pricey OEM parts.
spuds (10-27-18)
Injector open/close # 4 malfunction
I have a 2010 gs 350 with 150k one morning when I was going to work my rear of the vehicle start vibrating over 50 when I took it to the shop there was a P0204 injector open closed circuit short I changed the ecm and injector driver also the 4 injector and coil pack the shop seem to canter find the issue can some one please help me out
I second valex's question, and add my own: i have a 1997 ls400. The center support bearing, what is the latest year that uses the same bearing? For the option of finding a newer bearing from my local pick a part yard.
I bought an entire driveshaft from an JY with 95k miles for $55. So this might be the easier route since you won't have to pay a machine shop to press it on/off. I also got better condition rubber driveshaft bushings along with the swap that fixed my cracked and dried out AZ ones.
'OE replacement' is not OE. that's just jargon for 'aftermarket'.
I found that a lot of the vibrations are mitigated/removed just by replacing the transmission mount alone, not the center bearing.
the mount is very easy to replace and relatively cheap compared to the bearing.
the mount usually tears at 100k and upon close inspection looks fine, but mine was totally separated when uninstalled!
