Check Your Tranny Mount
Old 11-11-16, 09:28 AM
gebo
gebo's Avatar
Default Check Your Tranny Mount
Just replaced my tranny mount and all this weird vibration is gone. I thought it was my tires or suspension or motor mounts but it wasn't. At 250K a new transmission mount has my car driving and riding like a Lexus again.
You might want to check yours....
Old 11-11-16, 10:33 AM
Legender
Legender's Avatar
Known weakness... surprised you'd not changed it already...
Replaced some as early as 120k miles and possibly could have done it sooner.
Ok.. curious... that's a lot of cars listed, still owned by you?
I need a garage like yours if that's the case.
Old 11-11-16, 10:42 AM
gebo
gebo's Avatar
I had just gotten used to the vibration over time....
I have 2 driveways with one turn-a-round. 2 in garage, 2 in turn-a-round and 2 in lower driveway. I just own the LS430, LS400, GS300, and the 4Runner. The other 2 are our son's.
We do play shuffle a lot in the lower driveway. I just keep the 4Runner in the very bottom with the LS400 (daily driver) beside it. OF course, my wife's stays in Garage....r
Old 11-11-16, 11:12 AM
saleenssc
saleenssc's Avatar
How difficult was it to replace the tranny mount? Did you need to get it up on a lift or can it be done in the driveway? My car is a 98 LS400
thanks
Old 11-11-16, 02:35 PM
Scraape
Scraape's Avatar
thanks
tranny mount was easy, a LOT easier than the motor mounts. I did it in my driveway. I own a 98 as well
Old 11-11-16, 02:49 PM
EthanS
EthanS's Avatar
Hmmm I own a 99 LS at 167k. I've had it for 3.5 years, starting at 118k.
I have never noticed a vibration, especially one such that could be a tranny mount. I keep hearing how common it is for them to be worn though. Am I jaded to harshness after daily driving a modded s13 for so many years previous?
Just thinking out loud.. I have added this to my near future maintenance running list. Thanks
Old 11-11-16, 04:38 PM
jaaa
jaaa's Avatar
Mine was bad at 217k when I bought it.
Old 11-11-16, 08:56 PM
dicer
dicer's Avatar
I'm sure glad they knew how to make a good transmission mount in 90, mines still in good shape.
Old 11-13-16, 03:49 PM
Kburches
Kburches's Avatar
Maybe that is my clunking in the rear..? 97 LS400
Old 11-15-16, 04:01 PM
timmy0tool
timmy0tool's Avatar
thanks
fairly easy and a driveway job if you have two jackstands, a decent jack, and a piece of wood. I use the wood to isolate the jack while it's holding the transmission from the tranny oil pan.
a few bolts and the mount is off!
my mount at ~132k, completely separated!
Old 11-15-16, 07:04 PM
dicer
dicer's Avatar
Wow, what is that jack stand pushing on? I'd like a picture of what got smashed.
Old 11-16-16, 05:51 AM
Legender
Legender's Avatar
I've done it the same way with a piece of wood under the tranny pan. No damage as it does not take a lot of pressure to lift up the amount you need.
Great pics and very typical of the failure mode of the 3 tranny mounts I've replaced. Always improved the idle and removed the vibration.
Old 11-16-16, 08:21 AM
saleenssc
saleenssc's Avatar
thank you for the info and pictures. Sounds like i have all the tools needed to tackle this job.
Old 11-16-16, 09:41 AM
Scraape
Scraape's Avatar
mine was quite ****ed. this was with 250k+ miles on it
Old 11-16-16, 11:35 AM
timmy0tool
timmy0tool's Avatar
jackstand is on the jacking point (on both sides). I suppose it does look smashed but it's just the body line giving that illusion.
my jack is directly under the tranny oil pan with a piece of wood to better distribute the load.
Quick Reply: Check Your Tranny Mount
